Saltar al contenido principal
How to Fix Broken Porch Entry Stairs
Qué necesitas
  1. How to Fix Broken Porch Entry Stairs, Stair treads and risers: paso 1, imagen 1 de 3 How to Fix Broken Porch Entry Stairs, Stair treads and risers: paso 1, imagen 2 de 3 How to Fix Broken Porch Entry Stairs, Stair treads and risers: paso 1, imagen 3 de 3
    • Use a pry bar to remove the pre-existing damaged wood pieces.
    • Start with the riser first.
    • Be mindful of possible rusted screws/nails.
  2. How to Fix Broken Porch Entry Stairs: paso 2, imagen 1 de 3 How to Fix Broken Porch Entry Stairs: paso 2, imagen 2 de 3 How to Fix Broken Porch Entry Stairs: paso 2, imagen 3 de 3
    • Remove the treads on the stairs.
  3. How to Fix Broken Porch Entry Stairs: paso 3, imagen 1 de 2 How to Fix Broken Porch Entry Stairs: paso 3, imagen 2 de 2
    • Use a measuring tape to measure the foundation where the new steps will be placed.
    • To ensure accurate measurements, make sure to repeat this step twice.
  4. How to Fix Broken Porch Entry Stairs: paso 4, imagen 1 de 3 How to Fix Broken Porch Entry Stairs: paso 4, imagen 2 de 3 How to Fix Broken Porch Entry Stairs: paso 4, imagen 3 de 3
    • Mark your measurements on both ends of your new weather treated wood using a measuring tape and a pencil.
    • For the best results, use a ruler to connect your marks into a straight line.
  5. How to Fix Broken Porch Entry Stairs: paso 5, imagen 1 de 1
    • Place the new piece of wood onto the end of a sturdy table.
    • Make sure the marked end is hanging off the edge by at least a foot.
  6. How to Fix Broken Porch Entry Stairs: paso 6, imagen 1 de 1
    • Use a circular saw to cut across the straight line marked on the new piece of wood.
    • Make sure the wood is secure by holding the end resting on the table the entire time.
    • Safety glasses should be worn during this step.
  7. How to Fix Broken Porch Entry Stairs: paso 7, imagen 1 de 2 How to Fix Broken Porch Entry Stairs: paso 7, imagen 2 de 2
    • Place the new piece of wood (riser) on the steps to ensure that it fits.
    • Use a leveler to make sure that it is level.
  8. How to Fix Broken Porch Entry Stairs: paso 8, imagen 1 de 3 How to Fix Broken Porch Entry Stairs: paso 8, imagen 2 de 3 How to Fix Broken Porch Entry Stairs: paso 8, imagen 3 de 3
    • Secure your wood piece (riser) into place using a drill and galvanized screws.
    • Create two pilot holes with the correct drill bit.
    • Secure the wood (riser) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
  9. How to Fix Broken Porch Entry Stairs: paso 9, imagen 1 de 1
    • Make sure your wood piece (tread) fits into place and is level.
    • For the most accurate results, it is important to use a large level.
  10. How to Fix Broken Porch Entry Stairs: paso 10, imagen 1 de 3 How to Fix Broken Porch Entry Stairs: paso 10, imagen 2 de 3 How to Fix Broken Porch Entry Stairs: paso 10, imagen 3 de 3
    • Secure your wood piece (tread) into place using a drill and galvanized screws.
    • Create three pilot holes with the correct drill bit.
    • Secure the wood (tread) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
  11. How to Fix Broken Porch Entry Stairs: paso 11, imagen 1 de 1
    • Repeat steps 8-10 for the remaining stairs.
    • For the best results, follow this guide thoroughly for each stair.
Conclusión
To reassemble your old stairs, follow these instructions in reverse order.
Una persona más ha completado esta guía.
Kayla Unsworth
Miembro Desde 01/19/18
240 Reputación
1 Guía escrita
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 35
Todo El Tiempo: 9,475
