Saltar al contenido principal
How to Fix Bicycle Foam Handlebar Grips
Qué necesitas
  1. How to Fix Bicycle Foam Handlebar Grips, How to Fix Bicycle Foam Handlebar Grips: paso 1, imagen 1 de 3 How to Fix Bicycle Foam Handlebar Grips, How to Fix Bicycle Foam Handlebar Grips: paso 1, imagen 2 de 3 How to Fix Bicycle Foam Handlebar Grips, How to Fix Bicycle Foam Handlebar Grips: paso 1, imagen 3 de 3
    • Assess the problem area on your bike's handlebars.
  2. How to Fix Bicycle Foam Handlebar Grips: paso 2, imagen 1 de 2 How to Fix Bicycle Foam Handlebar Grips: paso 2, imagen 2 de 2
    • Lightly sand down the handlebar with the sandpaper.
    • Continue to sand the handlebar until no more residue falls.
  3. How to Fix Bicycle Foam Handlebar Grips: paso 3, imagen 1 de 2 How to Fix Bicycle Foam Handlebar Grips: paso 3, imagen 2 de 2
    • Boil water in a pot.
    • Once the water reaches boiling temperature (212°F/100°C), dip a rag into the water.
    • Be careful when handling the rag after it has been taken out of the boiling water. Handling the rag too quickly can result in a burn.
    • Take the soaked rag and begin cleaning the handlebar by applying pressure and rubbing in a downwards motion.
  4. How to Fix Bicycle Foam Handlebar Grips: paso 4, imagen 1 de 2 How to Fix Bicycle Foam Handlebar Grips: paso 4, imagen 2 de 2
    • Press a new, clean rag tightly to the opening of the alcohol bottle.
    • Tip the bottle upside down quickly and soak the rag with the alcohol.
    • Once the rag is soaked, start cleaning the handlebar again. Continue to clean the handlebar until there is no more visible residue coming off.
  5. How to Fix Bicycle Foam Handlebar Grips: paso 5, imagen 1 de 2 How to Fix Bicycle Foam Handlebar Grips: paso 5, imagen 2 de 2
    • Finally, bring the water to a boil once more.
    • Dip a rag into the water and begin rubbing the handlebar for the last time. Clean vigorously until the handlebar is noticeably smoother and no longer crumbling with residue.
Conclusión
Following these steps should result in handlebars that feel brand new!
3 personas más completaron esta guía.
Katy Haas
Miembro Desde 04/28/17
125 Reputación
1 Guía escrita
Equipo
UC Davis, Team S1-G1, Coad Spring 2017 Miembro de UC Davis, Team S1-G1, Coad Spring 2017
UCD-COAD-S17S1G1
4 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 54
Todo El Tiempo: 5,525
