Saltar al contenido principal
How to Fix Bent Silverware
Qué necesitas
  1. How to Fix Bent Silverware, How to Fix Bent Silverware: paso 1, imagen 1 de 2 How to Fix Bent Silverware, How to Fix Bent Silverware: paso 1, imagen 2 de 2
    • First, clean with soap and water all of the bent silverware.
  2. How to Fix Bent Silverware: paso 2, imagen 1 de 1
    • Take the pot and fill it halfway with water.
    • Put the pot on the stove and heat the water till it's boiling.
  3. How to Fix Bent Silverware: paso 3, imagen 1 de 1
    • Place the bent silverware in the water for at least one minute.
  4. How to Fix Bent Silverware: paso 4, imagen 1 de 1
    • After the minute is over, carefully pull out all of the silverware using pliers.
  5. How to Fix Bent Silverware: paso 5, imagen 1 de 1
    • Dry off the silverware with either paper or cloth towels. Be careful not to burn yourself.
  6. How to Fix Bent Silverware: paso 6, imagen 1 de 2 How to Fix Bent Silverware: paso 6, imagen 2 de 2
    • Use tools such as pliers, a hard surface, rulers, and/or hammers to reshape silverware as desired.
  7. How to Fix Bent Silverware: paso 7, imagen 1 de 1
    • When your done bending the silverware to its desired shape, let the silverware cool down to stay in that shape.
Linea de Meta
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 54
Todo El Tiempo: 3,110
