Saltar al contenido principal
How to Fix A Warped Frisbee Disc
Qué necesitas
  1. How to Fix A Warped Frisbee Disc, How to Fix A Warped Frisbee Disc: paso 1, imagen 1 de 2 How to Fix A Warped Frisbee Disc, How to Fix A Warped Frisbee Disc: paso 1, imagen 2 de 2
    • Place the frisbee disc on a flat surface with the concave side facing up. Lay a towel down flat over the frisbee.
  2. How to Fix A Warped Frisbee Disc: paso 2, imagen 1 de 1
    • Take the bowl and fill halfway full with water. Microwave until water is boiling.
    • The bowl will be hot, so handle it with care.
  3. How to Fix A Warped Frisbee Disc: paso 3, imagen 1 de 1
    • Take the bowl with boiling water and place it on top of the frisbee and the towel.
  4. How to Fix A Warped Frisbee Disc: paso 4, imagen 1 de 1
    • Add a textbook as a weight to sit on top of the bowl.
    • Let everything sit for 1 hour
  5. How to Fix A Warped Frisbee Disc: paso 5, imagen 1 de 1
    • Remove any weights, the bowl, and the towel. Check to see if the disc is still warped.
    • If it is still warped repeat this process one more time.
Conclusión
The time taken to fix the warping on your frisbee may vary based on how thick the plastic is.
2 personas más completaron esta guía.
Bryce Petersen
Miembro Desde 04/09/15
164 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 30-5, Green Spring 2015 Miembro de Cal Poly, Team 30-5, Green Spring 2015
CPSU-GREEN-S15S30G5
5 Miembros
32 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 14
Ultimos 30 días: 101
Todo El Tiempo: 9,744
