Saltar al contenido principal
How to Fix A Stripped Screw Hole
Qué necesitas
  1. How to Fix A Stripped Screw Hole, How to Fix A Stripped Screw Hole: paso 1, imagen 1 de 1
    • Using the toothpick as a reference, measure the depth of the screw-hole and the number of toothpicks needed to fill the screw hole.
  2. How to Fix A Stripped Screw Hole: paso 2, imagen 1 de 2 How to Fix A Stripped Screw Hole: paso 2, imagen 2 de 2
    • Next, using the wood glue, cover the area of the toothpick(s) that will fill in the screw hole.
  3. How to Fix A Stripped Screw Hole: paso 3, imagen 1 de 2 How to Fix A Stripped Screw Hole: paso 3, imagen 2 de 2
    • Place the toothpicks into the screw hole.
  4. How to Fix A Stripped Screw Hole: paso 4, imagen 1 de 1
    • Now, break off the exposed segment of the toothpick(s).
  5. How to Fix A Stripped Screw Hole: paso 5, imagen 1 de 1
    • Clean off the excess and let the wood glue dry for up to 30 minutes.
    • Recommended wood glue drying time may vary by product.
  6. How to Fix A Stripped Screw Hole: paso 6, imagen 1 de 2 How to Fix A Stripped Screw Hole: paso 6, imagen 2 de 2
    • Finally, using the screwdriver, screw the screw into the repaired screw hole.
Conclusión
Your screw should now hold secure.
Isaiah Valdez Mireles
Miembro Desde 08/22/22
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 19
Ultimos 30 días: 55
Todo El Tiempo: 1,535
