Saltar al contenido principal
How to Fix A Broken Makeup Compact Without Alcohol
Qué necesitas
  1. How to Fix A Broken Makeup Compact Without Alcohol, How to Fix A Broken Makeup Compact Without Alcohol: paso 1, imagen 1 de 1
    • Plug In the iron and turn the heat to the highest setting.
    • Caution: Be sure to place the iron on a flat, solid surface, away from plastic and other flammable objects.
  2. How to Fix A Broken Makeup Compact Without Alcohol: paso 2, imagen 1 de 1
    • Pour the broken powder into a plastic sandwich bag.
  3. How to Fix A Broken Makeup Compact Without Alcohol: paso 3, imagen 1 de 1
    • Use a spoon to break the powder down into a fine dust.
  4. How to Fix A Broken Makeup Compact Without Alcohol: paso 4, imagen 1 de 2 How to Fix A Broken Makeup Compact Without Alcohol: paso 4, imagen 2 de 2
    • Take a knife and carefully remove the metal pan from the compact.
  5. How to Fix A Broken Makeup Compact Without Alcohol: paso 5, imagen 1 de 3 How to Fix A Broken Makeup Compact Without Alcohol: paso 5, imagen 2 de 3 How to Fix A Broken Makeup Compact Without Alcohol: paso 5, imagen 3 de 3
    • Pour the powder into the metal pan and begin to press the powder down with the spoon.
  6. How to Fix A Broken Makeup Compact Without Alcohol: paso 6, imagen 1 de 3 How to Fix A Broken Makeup Compact Without Alcohol: paso 6, imagen 2 de 3 How to Fix A Broken Makeup Compact Without Alcohol: paso 6, imagen 3 de 3
    • Turn the heat off on the iron.
    • Caution: Be sure to unplug the iron.
    • Use the heat from the iron to secure the powder in the pan.
    • Press down for 15 seconds at a time.
    • Repeat as needed.
  7. How to Fix A Broken Makeup Compact Without Alcohol: paso 7, imagen 1 de 3 How to Fix A Broken Makeup Compact Without Alcohol: paso 7, imagen 2 de 3 How to Fix A Broken Makeup Compact Without Alcohol: paso 7, imagen 3 de 3
    • Let cool completely.
    • Place metal pan back into the compact.
    • Now the compact is ready for use.
Linea de Meta
Cura Mclemore
Miembro Desde 03/21/23
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 183
