Saltar al contenido principal
Introducción
A cracked door frame can often deteriorate in time but can be salvaged when fixed with a repair kit. This guide will help homeowners repair cracks in the door frame on their own and at a very low cost, without having to replace the entire door frame.
  1. Cracked door jamb/frame caused by excessive force on door.
    • Cracked door jamb/frame caused by excessive force on door.
  2. Apply wood filler into the cracks of the door frame.
    • Apply wood filler into the cracks of the door frame.
  3. Attach the clamp onto the cracked door frame. Use a clamp with rubber edges for a sturdier grip and also to prevent damaging the door frame.
    • Attach the clamp onto the cracked door frame.
    • Use a clamp with rubber edges for a sturdier grip and also to prevent damaging the door frame.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Drill a pilot hole into the door frame. Screw a 4-inch screw into the frame through the pilot hole.
    • Drill a pilot hole into the door frame.
    • Screw a 4-inch screw into the frame through the pilot hole.
  6. Wait for the wood filler to dry.
    • Wait for the wood filler to dry.
    • Once dried, scrape off the excess filler with a scraper.
  7. Sand the filled up cracks to get a smooth surface.
    • Sand the filled up cracks to get a smooth surface.
  8. Paint and do not touch until dry.
    • Paint and do not touch until dry.
  9. Repaired door frame/ door jamb. Repaired door frame/ door jamb.
    • Repaired door frame/ door jamb.
Linea de Meta
2 personas más completaron esta guía.
Anisha Karaumbiah
Miembro Desde 17/02/18
202 Reputación
1 Guía escrita
Equipo
UC Davis, Team S1-G1, Andersen Winter 2018 Miembro de UC Davis, Team S1-G1, Andersen Winter 2018
UCD-ANDERSEN-W18S1G1
2 Miembros
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 22
Últimos 7 Días: 127
Últimos 30 Días: 666
Todo El Tiempo: 3,516
