Introducción
Wire leads are attached inside to heat the toaster oven. Use this guide to repair the heating mechanism to regain use of your toaster oven.
Partes
No se requieren partes.
  1. If one of the heating mechanisms isn’t working, make sure all wire leads are attached inside the toaster oven.
    • If one of the heating mechanisms isn’t working, make sure all wire leads are attached inside the toaster oven.
      • When a broken lead is found, reattach by removing the screw at its original attachment point.
  2. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Make sure that the lead is attached and in contact.
    • Make sure that the lead is attached and in contact.
  4. Retighten screw to secure lead.
    • Retighten screw to secure lead.
Conclusión
Tony Wang
Miembro Desde 05/10/12
64 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 6-35, Regan Fall 2012 Miembro de Cal Poly, Team 6-35, Regan Fall 2012
CPSU-REGAN-F12S6G35
4 Miembros
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 19
Todo El Tiempo: 1,008
