Introducción
Use this guide to repair the power supply with a Phillips head screwdriver, a wrench, and pliers. These tools will help secure the screw holding the wire.
First, to remove the plastic bracket, turn toaster oven on its side.
  • First, to remove the plastic bracket, turn toaster oven on its side.
Agregar Comentario
Use Phillips head screwdriver and wrench to remove screw and nut securing the plastic bracket.
  • Use Phillips head screwdriver and wrench to remove screw and nut securing the plastic bracket.
Agregar Comentario
  • Use Phillips head screwdriver and pliers to remove screw and nut securing transformer.
Agregar Comentario
  • If the wire gets pulled out of the transformer, reinsert it.
  • Use a small flathead screwdriver to secure the screw that holds the wire in place.
Agregar Comentario
Conclusión
Tony Wang
Miembro Desde 05/10/12
64 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 6-35, Regan Fall 2012 Miembro de Cal Poly, Team 6-35, Regan Fall 2012
CPSU-REGAN-F12S6G35
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 670
