Saltar al contenido principal
How to Enlarge a Bikini Bottom
Qué necesitas
  1. How to Enlarge a Bikini Bottom, How to Enlarge a Bikini Bottom: paso 1, imagen 1 de 3 How to Enlarge a Bikini Bottom, How to Enlarge a Bikini Bottom: paso 1, imagen 2 de 3 How to Enlarge a Bikini Bottom, How to Enlarge a Bikini Bottom: paso 1, imagen 3 de 3
    • IMPORTANT: The following steps are only to repair a bikini bottom that is too small in order to make it adjustable to bigger sizes.
    • Use a tape measure to determine the amount of side seam you want to remove so that both sides are the same.
    • Pick the length based on your preference or needs. In this guide, I've removed 50.8 mm.
    • Use sewing scissors to cut 25.4 mm from each side at the seam.
  2. How to Enlarge a Bikini Bottom: paso 2, imagen 1 de 1
    • Fully extend the bikini bottom on a flat surface.
  3. How to Enlarge a Bikini Bottom: paso 3, imagen 1 de 3 How to Enlarge a Bikini Bottom: paso 3, imagen 2 de 3 How to Enlarge a Bikini Bottom: paso 3, imagen 3 de 3
    • Pick an elastic and measure around half a meter or 19 inches.
    • Cut the elastic in two halves, the long way.
    • You don't have to use an elastic, you can also use laces, ribbons, or material from old bikinis.
  4. How to Enlarge a Bikini Bottom: paso 4, imagen 1 de 3 How to Enlarge a Bikini Bottom: paso 4, imagen 2 de 3 How to Enlarge a Bikini Bottom: paso 4, imagen 3 de 3
    • Basic sewing knowledge is not required, but preferred.
    • Pay close attention when handling the sewing needle. Keep away from eyes or children.
    • To begin, sew the elastic directly to the bikini on the interior of the suit at all four sides with the the loose ends facing out.
    • The last picture shows how your bikini should look after sewing the elastic onto the fabric.
  5. How to Enlarge a Bikini Bottom: paso 5, imagen 1 de 3 How to Enlarge a Bikini Bottom: paso 5, imagen 2 de 3 How to Enlarge a Bikini Bottom: paso 5, imagen 3 de 3
    • To create a ruched look for the bikini and to finish the seam where you've sewn the elastic onto the fabric, sew between the middle of the fabric.
    • Repeat this step four times on each side of the bikini, two on the right and two on the left.
  6. How to Enlarge a Bikini Bottom: paso 6, imagen 1 de 1
    • Your final product should look like this. As a result, your bikini will now have two ties in each side of your hip where it can be tightened or loosened as you wish.
    • If your straps seem a little loose you can continue to sew over the fabric to tighten it a bit more.
Conclusión
If by the end of this guide your swimsuit is not yet of your liking you can add more elastic to your bikini or choose another style.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 35
Ultimos 30 días: 222
Todo El Tiempo: 2,506
