Saltar al contenido principal
How to Disconnect an iPad Battery with a Playing Card
Qué necesitas
  1. How to Disconnect an iPad Battery with a Playing Card, Mark the screw slot and total width: paso 1, imagen 1 de 2 How to Disconnect an iPad Battery with a Playing Card, Mark the screw slot and total width: paso 1, imagen 2 de 2
    • Line up the left edge of a playing card with the left edge of the battery connector.
    • Use a pen to mark both sides of the screw hole and the end of the battery connector as shown.
  2. How to Disconnect an iPad Battery with a Playing Card, Mark the depth of the screw slot: paso 2, imagen 1 de 2 How to Disconnect an iPad Battery with a Playing Card, Mark the depth of the screw slot: paso 2, imagen 2 de 2
    • Line up the top edge of the card with the top edge of the screw hole.
    • Use a pen to mark the bottom edge of the battery connector.
    • These markings will aid in cutting a slot in the card to clear the screw hole.
  3. How to Disconnect an iPad Battery with a Playing Card, Cut the playing card to size: paso 3, imagen 1 de 2 How to Disconnect an iPad Battery with a Playing Card, Cut the playing card to size: paso 3, imagen 2 de 2
    • The length of the battery blocker is not important, but we recommend it to be about an inch, or the length from the tip of your thumb to its knuckle.
    • Use a pair of scissors to cut out the playing card battery blocker as shown.
  4. How to Disconnect an iPad Battery with a Playing Card, Disconnect the battery: paso 4, imagen 1 de 3 How to Disconnect an iPad Battery with a Playing Card, Disconnect the battery: paso 4, imagen 2 de 3 How to Disconnect an iPad Battery with a Playing Card, Disconnect the battery: paso 4, imagen 3 de 3
    • Be extremely slow and careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • Insert the battery blocker at a 35 degree angle to disconnect the battery.
    • The playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at a 15 degree angle.
    • Leave the battery blocker in place as you work.
Conclusión
9 personas más completaron esta guía.
Robert Boyd
Miembro Desde 02/01/21
27,179 Reputación
94 Guías creadas
Un comentario
Thanks Robert. Great easy to create tool and excellent explanation.
Kevin Stark - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 13
Ultimos 7 días: 81
Ultimos 30 días: 284
Todo El Tiempo: 9,739
