Introducción
Before attempting to repair this toy you need to consider that the manufacturer has glued a cover over a screw. To remove this will leave a broken part (which you can glue on later) and that tool marks may remain visible (can mostly be smoothed back down with a warmed metal spatula/rod)
Herramientas
Partes
No se especificaron partes.
Remove 1 screw securing battery cover. Remove batteries.
remove 2 screws from dog belly that were hidden by battery cover.
Remove 2 screws-1 each next to front legs.
Use a plastic spudger to pry between upper and lower body.
Remove lower casing, front legs may still be attached to case but will easily pull free. When reattaching the body it is easiest to place legs in lower case and then place upper case on top.
remove 2 screws holding motor to battery compartment that were hidden beneath jack and wiring near battery opening.
Lift motor housing up slightly to allow battery compartment to be removed. You may have to "wiggle" neck joint/silver attachment to allow this.
The removed battery compartment. You will need to use a sharp blade to cut along joins to fully access battery contacts for a thorough clean.
6 personas más completaron esta guía.
Un Comentario
I struggled to remove the back cover to clean the battery corrosion off. So, I had an amazing idea. Q-tips and vinegar! I dipped a q-tip in vinager and reaches it down to the bottom of the compartment, cleaning it thoroughly. I dryed it with dry q-tips and small paper towel pieces. I placed new batteries inside and it worked again!
