Saltar al contenido principal
How to Descale a Breville Barista Pro BES878-RVC
Qué necesitas
  1. How to Descale a Breville Barista Pro BES878-RVC, How to Descale a Breville Barista Pro BES878-RVC: paso 1, imagen 1 de 1
    • Press the power button to power on the espresso machine.
  2. How to Descale a Breville Barista Pro BES878-RVC: paso 2, imagen 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: paso 2, imagen 2 de 2
    • Pull out and empty the water tank and drip tray.
  3. How to Descale a Breville Barista Pro BES878-RVC: paso 3, imagen 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: paso 3, imagen 2 de 2
    • Pull out the water filter from the water tank.
  4. How to Descale a Breville Barista Pro BES878-RVC: paso 4, imagen 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: paso 4, imagen 2 de 2
    • Pour a packet of descaler (or a descaler tablet) into the water tank.
    • Fill the water tank with fresh water to the descale line located on the side of the water tank.
    • If you do not have a descaler, pour a 1:1 mixture of white vinegar and water into the water tank instead.
  5. How to Descale a Breville Barista Pro BES878-RVC: paso 5, imagen 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: paso 5, imagen 2 de 2
    • Reinsert water tank and drip tray.
  6. How to Descale a Breville Barista Pro BES878-RVC: paso 6, imagen 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: paso 6, imagen 2 de 2
    • Position the steam wand above the drip tray.
    • If you wish to prevent splashing, place a tall bowl or cup under the steam wand.
  7. How to Descale a Breville Barista Pro BES878-RVC: paso 7, imagen 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: paso 7, imagen 2 de 2
    • Press the menu button.
    • Turn the knob labelled “Filter Size” counterclockwise until the “descale” label is blinking on the display.
  8. How to Descale a Breville Barista Pro BES878-RVC: paso 8, imagen 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: paso 8, imagen 2 de 2
    • Press down on the “Filter Size” knob to select descale.
    • The letter d will appear on the display and the one cup button will illuminate.
  9. How to Descale a Breville Barista Pro BES878-RVC: paso 9, imagen 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: paso 9, imagen 2 de 2
    • Press the one cup button to enter descale mode.
    • d3 will appear on the display and water will pour from the group head.
  10. How to Descale a Breville Barista Pro BES878-RVC: paso 10, imagen 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: paso 10, imagen 2 de 2
    • Wait for the display to show “d2.”
    • Rotate the right dial to the hot water icon to descale the hot water dispenser.
  11. How to Descale a Breville Barista Pro BES878-RVC: paso 11, imagen 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: paso 11, imagen 2 de 2
    • Wait for the display to show “d1.”
    • Rotate the right dial to the steam icon to descale the steam wand.
  12. How to Descale a Breville Barista Pro BES878-RVC: paso 12, imagen 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: paso 12, imagen 2 de 2
    • Wait for the display to show “r.”
    • Rotate the right dial back to the neutral position.
    • r means "rinse." You are now in the rinsing phase of descaling your espresso machine.
  13. How to Descale a Breville Barista Pro BES878-RVC: paso 13, imagen 1 de 3 How to Descale a Breville Barista Pro BES878-RVC: paso 13, imagen 2 de 3 How to Descale a Breville Barista Pro BES878-RVC: paso 13, imagen 3 de 3
    • Pull out and empty the water tank.
    • Fill the water tank with fresh water to the max line.
    • Reinsert the water tank.
  14. How to Descale a Breville Barista Pro BES878-RVC: paso 14, imagen 1 de 3 How to Descale a Breville Barista Pro BES878-RVC: paso 14, imagen 2 de 3 How to Descale a Breville Barista Pro BES878-RVC: paso 14, imagen 3 de 3
    • Pull out the drip tray.
    • Empty the drip tray.
    • Reinsert the drip tray.
  15. How to Descale a Breville Barista Pro BES878-RVC: paso 15, imagen 1 de 3 How to Descale a Breville Barista Pro BES878-RVC: paso 15, imagen 2 de 3 How to Descale a Breville Barista Pro BES878-RVC: paso 15, imagen 3 de 3
    • Press the one cup button to initiate the rinse cycle.
    • “r3” should appear on the display.
    • Wait for the display to show “r2”.
    • Rotate the right dial to the hot water icon to rinse the hot water dispenser.
  16. How to Descale a Breville Barista Pro BES878-RVC: paso 16, imagen 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: paso 16, imagen 2 de 2
    • Wait for the display to show “r1.”
    • Rotate the right dial to the steam icon to rinse the steam wand.
  17. How to Descale a Breville Barista Pro BES878-RVC: paso 17, imagen 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: paso 17, imagen 2 de 2
    • Once the rinse is complete, the grind amount option will appear on the display.
  18. How to Descale a Breville Barista Pro BES878-RVC: paso 18, imagen 1 de 3 How to Descale a Breville Barista Pro BES878-RVC: paso 18, imagen 2 de 3 How to Descale a Breville Barista Pro BES878-RVC: paso 18, imagen 3 de 3
    • Pull out the water tank.
    • Reinsert the water filter.
    • Refill the water tank with fresh water.
  19. How to Descale a Breville Barista Pro BES878-RVC: paso 19, imagen 1 de 1
    • Pull out and empty the drip tray.
  20. How to Descale a Breville Barista Pro BES878-RVC: paso 20, imagen 1 de 2 How to Descale a Breville Barista Pro BES878-RVC: paso 20, imagen 2 de 2
    • Reinsert the water tank and drip tray.
    • Your expresso machine should be clean and produce better tasting drinks!
Linea de Meta
Jeffery Huang
Miembro Desde 09/07/23
301 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 46
Ultimos 30 días: 289
Todo El Tiempo: 900
