Saltar al contenido principal
How to Decrease the Bicep of a Sleeve
Qué necesitas
  1. How to Decrease the Bicep of a Sleeve, How to Decrease the Bicep of a Sleeve: paso 1, imagen 1 de 3 How to Decrease the Bicep of a Sleeve, How to Decrease the Bicep of a Sleeve: paso 1, imagen 2 de 3 How to Decrease the Bicep of a Sleeve, How to Decrease the Bicep of a Sleeve: paso 1, imagen 3 de 3
    • Flip your shirt inside out.
    • The raw edges should be on the outside.
  2. How to Decrease the Bicep of a Sleeve: paso 2, imagen 1 de 3 How to Decrease the Bicep of a Sleeve: paso 2, imagen 2 de 3 How to Decrease the Bicep of a Sleeve: paso 2, imagen 3 de 3
    • Use a measuring tape to measure your desired width from the top point of the shoulder down to the seam of the shoulder.
    • Mark the bottom point of your measurement with a fabric pen or tailor's chalk.
  3. How to Decrease the Bicep of a Sleeve: paso 3, imagen 1 de 3 How to Decrease the Bicep of a Sleeve: paso 3, imagen 2 de 3 How to Decrease the Bicep of a Sleeve: paso 3, imagen 3 de 3
    • Use a fabric marker or tailor's chalk to draw a line from the marking, ensuring it aligns with the rest of the sleeve.
    • It should align with the sleeve at the cuff.
    • Draw another line from the marking, extending down to align with the side of the body of the shirt.
  4. How to Decrease the Bicep of a Sleeve: paso 4, imagen 1 de 3 How to Decrease the Bicep of a Sleeve: paso 4, imagen 2 de 3 How to Decrease the Bicep of a Sleeve: paso 4, imagen 3 de 3
    • Use straight pins to pin the sleeve across the lines you drew.
    • Push the pin through the top and push it back through the bottom of the sleeve.
    • Place a pin every inch across the lines.
  5. How to Decrease the Bicep of a Sleeve: paso 5, imagen 1 de 3 How to Decrease the Bicep of a Sleeve: paso 5, imagen 2 de 3 How to Decrease the Bicep of a Sleeve: paso 5, imagen 3 de 3
    • Using a sewing machine, sew across the pinned lines with a straight stitch.
    • Be sure to backstitch at the start and end of your stitch.
  6. How to Decrease the Bicep of a Sleeve: paso 6, imagen 1 de 3 How to Decrease the Bicep of a Sleeve: paso 6, imagen 2 de 3 How to Decrease the Bicep of a Sleeve: paso 6, imagen 3 de 3
    • Use scissors to cut off the excess fabric.
    • Leave a seam allowance of 6.4 mm.
  7. How to Decrease the Bicep of a Sleeve: paso 7, imagen 1 de 1
    • Measure again to see if you reached your desired width.
Conclusión
Now that you have finished your fix, go ahead and try on that perfect-fitting shirt. Thank you for picking this fast fix guide!
Una persona más ha completado esta guía.
Elliot T
Miembro Desde 09/27/23
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 140
