Introducción
This guide provides instructions on how to remove a physical blockage from a Keurig K-Mini. A blockage in the machine can cause an array of issues, such as the hot beverage spurting out of the machine, or not allowing the beverage to dispense at all. A small pointed tool will be needed for this repair, such as a thumbtack, sewing needle, or toothpick. The guide instructs users on how to safely use this pointed object to successfully remove the blockage so that beverages will dispense properly.
Qué necesitas
Unplug the Keurig from the power source.
Lift the handle and locate the pod holder.
Run the machine on the largest cup setting while leaving the pod holder empty. This will show if the blockage has been removed, or if the process will need to be repeated to loosen the blockage. Potential blockages may also be removed during this cycle.
4 personas más completaron esta guía.
