Saltar al contenido principal
How to Clean the Fan on a Toshiba TDP-XP2
Qué necesitas
  1. How to Clean the Fan on a Toshiba TDP-XP2, How to Clean the Fan on a Toshiba TDP-XP2: paso 1, imagen 1 de 2 How to Clean the Fan on a Toshiba TDP-XP2, How to Clean the Fan on a Toshiba TDP-XP2: paso 1, imagen 2 de 2
    • Remove the two screws from the bottom plate as shown.
  2. How to Clean the Fan on a Toshiba TDP-XP2: paso 2, imagen 1 de 1
    • Remove the two screws on the bulb housing.
  3. How to Clean the Fan on a Toshiba TDP-XP2: paso 3, imagen 1 de 1
    • Pull the tab up and pull the bulb out vertically. Some force will be required, but it will come out.
  4. How to Clean the Fan on a Toshiba TDP-XP2: paso 4, imagen 1 de 1
    • Using a can of compressed air, blow on the fan until all dust is gone.
    • Oil can be added in with a dropper on the bearing if needed.
Conclusión
Bryan Underwood
Miembro Desde 04/02/18
697 Reputación
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 409
