Saltar al contenido principal
How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter
Qué necesitas
  1. How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter, How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: paso 1, imagen 1 de 2 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter, How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: paso 1, imagen 2 de 2
    • Turn off the air conditioner unit manually or with the remote control.
    • Unplug the A/C unit from its power source.
  2. How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: paso 2, imagen 1 de 2 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: paso 2, imagen 2 de 2
    • Place your hands on the opposite sides of the air conditioner and unclip the grille from the unit.
  3. How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: paso 3, imagen 1 de 3 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: paso 3, imagen 2 de 3 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: paso 3, imagen 3 de 3
    • Gently grab the front grille and place it on the ground or table.
    • Use your hands to pull the filter out of the unit
  4. How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: paso 4, imagen 1 de 2 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: paso 4, imagen 2 de 2
    • Carry the filter to a faucet and flush with water to eliminate dust particles.
    • Lay down the clean air filter on a towel until it's completely dry.
    • The filter will take about five to eight minutes to dry.
    • Do not place a wet filter back into the unit. Placing a damp filter in the unit can cause water damage to the air conditioner.
  5. How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: paso 5, imagen 1 de 3 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: paso 5, imagen 2 de 3 How to Clean an LG Goldstar BG5200ER Air Conditioner Air Filter: paso 5, imagen 3 de 3
    • Replace the air filter between the front grille and evaporated coil.
    • Clip the front grille back to the unit and push the grille to align the sides with the clips.
Conclusión
To reassemble the air conditioner, replug the A/C unit cord to the power outlet and turn it on.
2 personas más completaron esta guía.
Angel R. Mariscal
Miembro Desde 03/24/22
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 45
Todo El Tiempo: 1,200
