Introducción
The Nikon D750 is a digital single mirror reflex camera released by Nikon on on September 12, 2014. This camera has a LCD display on the rear. It is 140.5mm long and about 113mm tall, with a thickness around 78mm. The weight is approximately 840g (with battery and memory card, but excluding the body cover), or about 750 g (camera body only). Nobody likes having odd spots and marks on their images, so follow through this guide to get rid of them for good!
Qué necesitas
Power on the camera by moving the switch to the "On" position.
Make the aperture (the hole in the lens) small by turning the wave wheel to the right. The wave wheel is located in front of the camera and beneath the “Off/On” button. Turn the wheel until it reaches “F16” on the screen.
Confirm the Location of the Stain: Press the shutter against a plain white surface and take a picture. If the camera sensor has dust or debris covering it, then there will be darker spots on the image.
The Nikon d750 I introduced is a full frame camera developed by Nikon in 2014. Although the CMOS of this professional camera is very valuable, it is far from as fragile as it is now. Compared with CMOS, SLR reflector and focus screen camera are actually more fragile. The width of the full CMOS frame is different from that of the full CMOS frame of 35mm / 4 inches. Choosing an appropriate width can reduce the number of wipes.Therefore, the ideal effect can be achieved by selecting appropriate tools according to the appropriate frame size of the camera
2 personas más completaron esta guía.
