Saltar al contenido principal
How to Clean a Dirt Devil Vacuum Cleaner Roller Brush
Qué necesitas
  1. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush, How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: paso 1, imagen 1 de 1
    • Lay the vacuum cleaner on the floor so that the bottom of the vacuum is facing upwards.
  2. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: paso 2, imagen 1 de 1
    • Use a Phillips head screwdriver to remove eight screws.
  3. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: paso 3, imagen 1 de 1
    • Disassemble the vacuum head and pop out your roller brush.
  4. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: paso 4, imagen 1 de 1
    • Cut the ends with scissors.
    • Cover the floor with papers to prevent debris and hair from falling on the ground.
  5. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: paso 5, imagen 1 de 1
    • Use a brush to clean the roller brush.
  6. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: paso 6, imagen 1 de 2 How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: paso 6, imagen 2 de 2
    • Put the rectangular part on both sides.
  7. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: paso 7, imagen 1 de 2 How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: paso 7, imagen 2 de 2
    • Check if the belt is attached.
    • Check if the motor part is well inserted with the belt attached to the roller brush.
    • Make sure the shape of the motor fits to prevent it from falling.
  8. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: paso 8, imagen 1 de 1
    • Use your Phillips head screwdriver to screw in all eight of the screws.
Linea de Meta
Una persona más ha completado esta guía.
4 comentarios
Might be helpful if you showed where all 8 screws are seeing how I can only find 6 and cannot get it open!
Crystal - Contestar
in the front there are to wheels, pop them out and you will see the other 2 screws
Mario Lore -
my power express lite only has 6 screws as well. I cannot get it open, I'm afraid it will break if I keep prying.
Gregory Penniston - Contestar
Can I hand wash the brushes and rollers.
Lynne - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 37
Ultimos 30 días: 266
Todo El Tiempo: 8,056
