Saltar al contenido principal
How to Clean The Exit Needle of the Keurig B60
Qué necesitas
  1. How to Clean The Exit Needle of the Keurig B60, How to Clean The Exit Needle of the Keurig B60: paso 1, imagen 1 de 1
    • Lift Handle to open Lid
  2. How to Clean The Exit Needle of the Keurig B60: paso 2, imagen 1 de 3 How to Clean The Exit Needle of the Keurig B60: paso 2, imagen 2 de 3 How to Clean The Exit Needle of the Keurig B60: paso 2, imagen 3 de 3
    • Remove K-Cup Pack Holder Assembly by pinching the left and right sides to release clamp. Wiggle slightly to remove
  3. How to Clean The Exit Needle of the Keurig B60: paso 3, imagen 1 de 3 How to Clean The Exit Needle of the Keurig B60: paso 3, imagen 2 de 3 How to Clean The Exit Needle of the Keurig B60: paso 3, imagen 3 de 3
    • Pull and snap apart the funnel from the K-Cup Pack Holder (If this is the first time separating the Pack Holder Assembly, more force may be required)
  4. How to Clean The Exit Needle of the Keurig B60: paso 4, imagen 1 de 2 How to Clean The Exit Needle of the Keurig B60: paso 4, imagen 2 de 2
    • Insert a paperclip or other small, sharp object into the bottom of the K-Cup Pack Holder needle compartment to clear out any debris. If debris is too dry and compact, perform this step under running water to loosen the debris
    • Flip K-Cup Pack Holder and repeat
  5. How to Clean The Exit Needle of the Keurig B60: paso 5, imagen 1 de 2 How to Clean The Exit Needle of the Keurig B60: paso 5, imagen 2 de 2
    • With the Lid still open, locate the Puncture Needle. Insert a paperclip or other small sharp object into the Puncture Needle Holes to remove any debris trapped inside
Conclusión
Once reassembled, run the brewer once or twice with just water to cleanse the system.
10 personas más completaron esta guía.
Jake Wynn
Miembro Desde 04/11/16
830 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 1-7, Maness Spring 2016 Miembro de Cal Poly, Team 1-7, Maness Spring 2016
CPSU-MANESS-S16S1G7
5 Miembros
5 Guías creadas
2 comentarios
I used the needle but it fell into the area.  How do I get the needle out?
pspicuzza - Contestar
The bottom needle is loose on small piece of plastic is this normal or broke?
confused40 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 18
Ultimos 30 días: 72
Todo El Tiempo: 26,658
