Saltar al contenido principal
How to Clean PDP Afterglow Deluxe+ Button Contacts
Qué necesitas
  1. How to Clean PDP Afterglow Deluxe+ Button Contacts, How to Clean PDP Afterglow Deluxe+ Button Contacts: paso 1, imagen 1 de 1
    • Use a screwdriver to remove the six screws from the back of the controller.
  2. How to Clean PDP Afterglow Deluxe+ Button Contacts: paso 2, imagen 1 de 2 How to Clean PDP Afterglow Deluxe+ Button Contacts: paso 2, imagen 2 de 2
    • Open up the shell and remove the weights in the grips.
  3. How to Clean PDP Afterglow Deluxe+ Button Contacts: paso 3, imagen 1 de 3 How to Clean PDP Afterglow Deluxe+ Button Contacts: paso 3, imagen 2 de 3 How to Clean PDP Afterglow Deluxe+ Button Contacts: paso 3, imagen 3 de 3
    • Pull out the battery and remove the screws underneath.
    • This component is glued to the controller, so it may take some force to remove.
    • Remove the two screws on the circuit board.
  4. How to Clean PDP Afterglow Deluxe+ Button Contacts: paso 4, imagen 1 de 2 How to Clean PDP Afterglow Deluxe+ Button Contacts: paso 4, imagen 2 de 2
    • Remove the circuit board from the shell.
  5. How to Clean PDP Afterglow Deluxe+ Button Contacts: paso 5, imagen 1 de 1
    • Use a cotton swab to clean up the areas the buttons come in contact with.
Conclusión
TJay Vitoorakorn
Miembro Desde 10/25/23
121 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 50
Todo El Tiempo: 294
