Saltar al contenido principal
How to Change a String and Cable on a Matthew Genesis Bow
Qué necesitas
  1. How to Change a String and Cable on  a Matthew Genesis Bow, String: paso 1, imagen 1 de 3 How to Change a String and Cable on  a Matthew Genesis Bow, String: paso 1, imagen 2 de 3 How to Change a String and Cable on  a Matthew Genesis Bow, String: paso 1, imagen 3 de 3
    • Familiarize yourself with each of the parts of the bow; Idle wheel, cam, and cable slide in that order.
  2. How to Change a String and Cable on  a Matthew Genesis Bow: paso 2, imagen 1 de 3 How to Change a String and Cable on  a Matthew Genesis Bow: paso 2, imagen 2 de 3 How to Change a String and Cable on  a Matthew Genesis Bow: paso 2, imagen 3 de 3
    • Disassemble the bow by using inserting the 3/16th Allen wrench into the hole at the front of the bow.
    • Loosen each side by performing three counter-clockwise turns at the top, three counter-clockwise turns at the bottom, four counter-clockwise turns at the top, and then four counter-clockwise turns at the bottom. There should not be any tension left on the strings.
  3. How to Change a String and Cable on  a Matthew Genesis Bow: paso 3, imagen 1 de 1
    • Slide off the cable slide.
  4. How to Change a String and Cable on  a Matthew Genesis Bow: paso 4, imagen 1 de 3 How to Change a String and Cable on  a Matthew Genesis Bow: paso 4, imagen 2 de 3 How to Change a String and Cable on  a Matthew Genesis Bow: paso 4, imagen 3 de 3
    • Take the black and red string off of the pegs of the cam. Then unhook the string from the idler wheel.
  5. How to Change a String and Cable on  a Matthew Genesis Bow: paso 5, imagen 1 de 3 How to Change a String and Cable on  a Matthew Genesis Bow: paso 5, imagen 2 de 3 How to Change a String and Cable on  a Matthew Genesis Bow: paso 5, imagen 3 de 3
    • Unhook the black power cable from both the cam and idler wheel.
  6. How to Change a String and Cable on  a Matthew Genesis Bow: paso 6, imagen 1 de 3 How to Change a String and Cable on  a Matthew Genesis Bow: paso 6, imagen 2 de 3 How to Change a String and Cable on  a Matthew Genesis Bow: paso 6, imagen 3 de 3
    • To reassemble, twist the two-sided black power cord. Twist it two times and the other side one time.
    • The side that was twisted twice should be placed on the same side as the cable side on the idler wheel.
  7. How to Change a String and Cable on  a Matthew Genesis Bow: paso 7, imagen 1 de 2 How to Change a String and Cable on  a Matthew Genesis Bow: paso 7, imagen 2 de 2
    • Spin the cam until the peg is showing on the inside towards the cable rod. Attach the black power cord to the peg. Make sure it is between the pegs when going through the cam as seen below.
  8. How to Change a String and Cable on  a Matthew Genesis Bow: paso 8, imagen 1 de 2 How to Change a String and Cable on  a Matthew Genesis Bow: paso 8, imagen 2 de 2
    • Find the end with the longest-serving (the black part of your string) of your black and red string. It is the starting side. As seen in the image the top sting is the longest-serving because it does not have red intertwined. Attach it to the cam on the peg and wrap it around the groove between the limbs and feed it through.
  9. How to Change a String and Cable on  a Matthew Genesis Bow: paso 9, imagen 1 de 3 How to Change a String and Cable on  a Matthew Genesis Bow: paso 9, imagen 2 de 3 How to Change a String and Cable on  a Matthew Genesis Bow: paso 9, imagen 3 de 3
    • Hook the string to the cam again by putting it between the bow with limbs up, around the idler wheel, under your cable rod, and over the limbs.
  10. How to Change a String and Cable on  a Matthew Genesis Bow: paso 10, imagen 1 de 1
    • Put the cable slide back on the string.
  11. How to Change a String and Cable on  a Matthew Genesis Bow: paso 11, imagen 1 de 3 How to Change a String and Cable on  a Matthew Genesis Bow: paso 11, imagen 2 de 3 How to Change a String and Cable on  a Matthew Genesis Bow: paso 11, imagen 3 de 3
    • Check that all the strings are secure in the grooves on the cams. Do this by running your hand along the string making sure it is flat and tight unlike the above image.
  12. How to Change a String and Cable on  a Matthew Genesis Bow: paso 12, imagen 1 de 3 How to Change a String and Cable on  a Matthew Genesis Bow: paso 12, imagen 2 de 3 How to Change a String and Cable on  a Matthew Genesis Bow: paso 12, imagen 3 de 3
    • Tighten both sides of your bow with your Allen wrench with clockwise rotations.
Linea de Meta
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 33
Todo El Tiempo: 1,081
