Start by loosening the string you are trying to replace by twisting the pegs.
The G and C tuning pegs turn up to tighten and down to loosen while the E and A tuning pegs turn down to tighten and up to loosen.
Next, grab the new string you are using to replace.
The packaging will inform you of which string replaces which note—some are different than others so pay attention!
Incrustar esta guía
Elige el tamaño y copia el siguiente código para insertar esta guía como un pequeño widget en tu sitio web o foro.
Vista previa
