Saltar al contenido principal
How to Change Broken Buttons on your Lexus Key Fob
  1. How to Change Broken Buttons on your Lexus Key Fob, Broken Buttons: paso 1, imagen 1 de 2 How to Change Broken Buttons on your Lexus Key Fob, Broken Buttons: paso 1, imagen 2 de 2
    • Place the key fob with the removable metal key facing towards you.
  2. How to Change Broken Buttons on your Lexus Key Fob: paso 2, imagen 1 de 3 How to Change Broken Buttons on your Lexus Key Fob: paso 2, imagen 2 de 3 How to Change Broken Buttons on your Lexus Key Fob: paso 2, imagen 3 de 3
    • With the button side facing you, pull the metal latch down towards you to pull out the key.
  3. How to Change Broken Buttons on your Lexus Key Fob: paso 3, imagen 1 de 3 How to Change Broken Buttons on your Lexus Key Fob: paso 3, imagen 2 de 3 How to Change Broken Buttons on your Lexus Key Fob: paso 3, imagen 3 de 3
    • With the exposed corner facing you, place the metal key into the slot.
    • Turn the key sideways to open the key fob.
    • You may feel like you're breaking the key fob, but be firm while twisting.
  4. How to Change Broken Buttons on your Lexus Key Fob: paso 4, imagen 1 de 2 How to Change Broken Buttons on your Lexus Key Fob: paso 4, imagen 2 de 2
    • Remove the motherboard and battery to access the buttons.
  5. How to Change Broken Buttons on your Lexus Key Fob: paso 5, imagen 1 de 3 How to Change Broken Buttons on your Lexus Key Fob: paso 5, imagen 2 de 3 How to Change Broken Buttons on your Lexus Key Fob: paso 5, imagen 3 de 3
    • Rotate the front plate, the broken buttons should fall out with ease.
    • Replace the broken buttons as necessary.
Conclusión
To reassemble your device, follow these instructions in reverse order. Apply firm pressure when snapping the front and back covers together.
7 personas más completaron esta guía.
Michael Tan
Miembro Desde 01/08/15
587 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 30-3, Green Spring 2015 Miembro de Cal Poly, Team 30-3, Green Spring 2015
CPSU-GREEN-S15S30G3
4 Miembros
10 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 16
Ultimos 30 días: 56
Todo El Tiempo: 6,160
