Guía en vídeo
Esta guía ha sido transcrita de un vídeo de YouTube.
Introducción
Ir al paso 1 ↓When your Frigidaire oven displays the right temperature but food still undercooks or overcooks, the control may be out of calibration. A simple offset adjustment can bring the displayed setting back in line with the actual oven temperature and improve cooking results. This guide shows you how to measure the true temperature with a metal oven thermometer, calculate the required offset, and program that offset using either of two common Frigidaire calibration procedures.
Qué necesitas
Herramientas
Paso 1 Gather a thermometer and locate the sensor
Use a metal oven thermometer rated for high temperatures.
Locate the small sensor rod in the upper back corner of the oven cavity.
Paso 2 Position the thermometer and heat the oven
Place the thermometer on the rack near the sensor, ideally in the back left corner.
Close the door and set Bake to 375 °F or 400 °F.
Paso 3 Determine the temperature offset
Record the stabilized thermometer temperature once it holds steady.
Subtract the thermometer reading from the set temperature to find the difference.
Use that difference to determine how much to raise or lower the offset.
Paso 5 Enter calibration mode method 1
Press and hold the Bake button for 5–10 seconds until the display shows 0 °F.
Release the button when 0 °F appears to enter calibration mode.
Paso 6 Enter calibration mode method 2
Press Bake to wake the control, then turn the temperature to 550 °F.
Release the control, then press and hold Bake for 5 seconds.
Paso 7 Adjust the temperature offset
Use the Up and Down arrow keys to change the displayed temperature offset.
Positive numbers make the oven run hotter; negative numbers make it cooler.
Set the offset equal to the difference measured earlier without exceeding the board limit.
Paso 8 Save the new setting
Stop pressing buttons and wait about 5 to 10 seconds for the display to return to normal.
Paso 9 Verify operation and troubleshoot
Repeat the temperature test to verify that the oven now matches the set temperature.
After saving the new offset, verify that the oven reaches the expected temperature during the next preheat cycle. Repair didn't go as planned? Ask our Answers community for help.
