Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Build and Use a Test Cord for Appliance Testing
Guía en vídeo
Esta guía ha sido transcrita de un vídeo de YouTube.
Qué necesitas
    • Work on a dry, non-conductive surface with the appliance part secured so it can’t roll, spin, or move when powered.
    • WARNING: This procedure uses live mains voltage, which can cause shock, burns, or death.
    • Unplug the test cord any time you’re attaching wires or changing configurations.
    • Keep fingers, tools, jewelry, and loose clothing away from exposed terminals and moving parts.
    • Use a GFCI-protected outlet if possible, and don’t test parts near water.
    Pregunta a FixBot
    Agregar Comentario
    • Get a basic two-prong lamp cord with an inline on/off switch.
    • Get 14 AWG female spade terminals that match the tabs on the parts you plan to test.
    • Get a kilowatt meter if you want to measure watts, volts, and amps while testing.
    • Use a quality crimping tool, since low-quality crimp connectors can fail and waste time and money.
    • Use a wire stripper or cutter as needed for your cord and terminals.
    Pregunta a FixBot
    Agregar Comentario
    • Open the cord end you’ll be adding connectors to, so the two conductors are accessible.
    • Strip enough insulation from each conductor to fit fully into the spade terminal barrel you’re using.
    • Twist the exposed wire strands on each conductor so they’re tight and secure.
    • Caution: Don’t leave stray strands outside the terminal, since they can short to the other wire or to metal parts.
    Pregunta a FixBot
    Agregar Comentario
    • Slide a 14 AWG female spade terminal onto a prepared wire end until the copper is fully inside the barrel.
    • Use the blue crimp position on the crimping tool for these 14 AWG terminals.
    • Crimp the terminal firmly, then pull on the wire to confirm it won’t slip out.
    • Repeat the strip, twist, and crimp process for the second conductor.
    • A test cord is a good place to practice crimping, since a bad crimp can cause poor contact and unsafe heating.
    Pregunta a FixBot
    Agregar Comentario
    • Plug the kilowatt meter into the wall outlet.
    • Plug the cheater cord into the kilowatt meter, and set the cord’s switch to Off.
    • Use the meter to view watts and other readings while the part is running.
    • Caution: Treat the spade terminals as live whenever the cord is plugged in, even if the switch is Off.
    Pregunta a FixBot
    Agregar Comentario
    • Attach the two female spade terminals to the drain pump’s two terminals.
    • Identify which pump wire is live and which is neutral before powering the pump.
    • In this configuration, the live is on the blue wire and the neutral is on the brown wire.
    • Turn the cord’s switch On to run the pump and read the wattage on the kilowatt meter.
    • If you suspect polarity affects the pump’s rotation, shut the switch Off, unplug the cord, swap the connections, and test again.
    • Caution: Don’t intentionally jam or obstruct a running pump with tools, since you can damage the part and seriously injure yourself.
    Pregunta a FixBot
    Agregar Comentario
    • Connect the cheater cord’s spade terminals to the heater wiring using the existing piggyback connectors so the terminals can be swapped quickly.
    • Turn the cord’s switch On and watch the kilowatt meter to see the heater’s power draw.
    • Carefully feel for heat at a safe distance and verify the element is warming.
    • Caution: Heater elements get hot enough to burn skin and ignite nearby materials, so keep the element away from plastic, paper, and wiring insulation.
    • In this test, the meter showed about 13.4 to 13.5 watts, and the heater produced a noticeable temperature increase.
    Pregunta a FixBot
    Agregar Comentario
    • Switch the cord Off and confirm the meter drops to zero watts before handling any connections.
    • Unplug the cord from the meter, then unplug the meter from the wall outlet.
    • Inspect each crimp for a tight fit, since poor-quality crimp terminals can fail and cause unreliable tests.
    • Build multiple cords if you want different end connectors, such as versions with male connectors for plug-in style connections.
    • Reminder: Store the cheater cord with the switch set to Off so it’s less likely to be energized accidentally during setup.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Use the cheater cord and kilowatt meter to verify that a component runs, heats, or draws power in a way that matches expectations. Keep tests short, keep terminals covered and away from contact, and unplug the cord before touching or swapping any spade connections. Repair didn't go as planned? Ask our Answers community for help.
2 personas más completaron esta guía.
Ben Schlichter
Miembro Desde 01/21/25
7,100 Reputación
224 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 28
Ultimos 30 días: 172
Todo El Tiempo: 894
