Saltar al contenido principal
How to Blanket Stitch
Qué necesitas
  1. How to Blanket Stitch, How to Blanket Stitch: paso 1, imagen 1 de 2 How to Blanket Stitch, How to Blanket Stitch: paso 1, imagen 2 de 2
    • Pick a thread of your choice: fabric or sewing thread.
    • Cut a relatively long piece.
  2. How to Blanket Stitch: paso 2, imagen 1 de 3 How to Blanket Stitch: paso 2, imagen 2 de 3 How to Blanket Stitch: paso 2, imagen 3 de 3
    • Pull one end of thread through the eye of the needle.
    • Make the two tail ends meet.
    • Tie a knot.
  3. How to Blanket Stitch: paso 3, imagen 1 de 1
    • Lay your blanket (or piece of fabric) in front of you and pick your stitching direction.
    • We are stitching left to right!
  4. How to Blanket Stitch: paso 4, imagen 1 de 2 How to Blanket Stitch: paso 4, imagen 2 de 2
    • Measure about half an inch from the edge of your blanket and mark it.
    • Send your needle through the blanket from the back from the marked point.
    • When pushing your needle through the blanket make sure your fingers are not near the needle.
  5. How to Blanket Stitch: paso 5, imagen 1 de 1
    • Bring the thread around the fabric and push the needle through the very first stich creating a loop.
    • Do not pull the thread all the way though, as you will need the loop for the next step.
  6. How to Blanket Stitch: paso 6, imagen 1 de 2 How to Blanket Stitch: paso 6, imagen 2 de 2
    • Push the needle through the loop and pull.
  7. How to Blanket Stitch: paso 7, imagen 1 de 3 How to Blanket Stitch: paso 7, imagen 2 de 3 How to Blanket Stitch: paso 7, imagen 3 de 3
    • Move about half an inch from the first stitch.
    • Send the needle through the blanket from the back creating a loop.
  8. How to Blanket Stitch: paso 8, imagen 1 de 2 How to Blanket Stitch: paso 8, imagen 2 de 2
    • Push the needle through the loop and pull and repeat!
  9. How to Blanket Stitch: paso 9, imagen 1 de 2 How to Blanket Stitch: paso 9, imagen 2 de 2
    • Repeat the process through the edge of your blanket till you reach the end.
Conclusión
To reverse these steps, use a pair of scissors to cut the thread.
Una persona más ha completado esta guía.
katya
Miembro Desde 05/10/21
196 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 39
Todo El Tiempo: 912
