Introducción
If the letters typed by your Remington Quiet Riter typewriter are lighter on the top or bottom, or if your capital letters do not align with your lowercase letters, this guide will help you try a simple "on feet" adjustment to align your type.
Keep in mind that this process will involve some trial and error. Be careful to hold the adjustment screw in place when tightening or loosening the nut. Also, it helps to keep track of how much you adjust the screw each time so you can more easily find the correct alignment.
Qué necesitas
Lightly type a row of lowercase letters.
Return the carriage, then hold the shift key and lightly type a row of uppercase letters.
Return the carriage, and type a capital H followed by a lowercase h.
Examine the letters you typed to identify alignment issues.
If the lowercase letters are not a uniform darkness, you will adjust the lowercase screw.
If the uppercase letters are not a uniform darkness, you will adjust the uppercase screw.
If all of the letters are a uniform darkness, but the bottom of the capital H does not align with the bottom of the lowercase h, you will need to experiment with adjustments to find the correct alignment.
Your typewriter should be aligned! Type something to test it out.
Una persona más ha completado esta guía.
