Saltar al contenido principal
How to Adjust the Truss Rod on an Acoustic Guitar
Qué necesitas
  1. How to Adjust the Truss Rod on an Acoustic Guitar, How to Adjust the Truss Rod on an Acoustic Guitar: paso 1, imagen 1 de 3 How to Adjust the Truss Rod on an Acoustic Guitar, How to Adjust the Truss Rod on an Acoustic Guitar: paso 1, imagen 2 de 3 How to Adjust the Truss Rod on an Acoustic Guitar, How to Adjust the Truss Rod on an Acoustic Guitar: paso 1, imagen 3 de 3
    • Unwind and remove the strings
    • Turn the tuning pegs to release tension in the strings, and then pull the strings away, detaching them from the headstock
  2. How to Adjust the Truss Rod on an Acoustic Guitar: paso 2, imagen 1 de 3 How to Adjust the Truss Rod on an Acoustic Guitar: paso 2, imagen 2 de 3 How to Adjust the Truss Rod on an Acoustic Guitar: paso 2, imagen 3 de 3
    • Remove the truss rod cover with the necessary tool (depending on your guitar).
    • A Phillips 0 screwdriver is used here to unscrew the 2 x 1/4" Small Phillips guitar screws from the truss rod cover.
    • There are three screws holding the truss rod cover in place.
  3. How to Adjust the Truss Rod on an Acoustic Guitar: paso 3, imagen 1 de 2 How to Adjust the Truss Rod on an Acoustic Guitar: paso 3, imagen 2 de 2
    • Use the Allen Wrench to adjust the truss rod according to the warp of the neck.
    • For a forward or “U-shaped” bow, turn the truss rod counterclockwise. For a backward bow adjustment, adjust the truss rod clockwise.
    • A “U-shaped” bow is too tight; it has extra space toward the center of the neck, and bows outward and toward the strings. A backward bow is too loose; it arches inward and away from the strings.
  4. How to Adjust the Truss Rod on an Acoustic Guitar: paso 4, imagen 1 de 3 How to Adjust the Truss Rod on an Acoustic Guitar: paso 4, imagen 2 de 3 How to Adjust the Truss Rod on an Acoustic Guitar: paso 4, imagen 3 de 3
    • Re-string the guitar by reattatching them to the headstock.
    • Turn the tuning pegs to bring the strings back to tension.
    • At the same time, adjust the bridge evenly with the neck ( if it is not already glued into the saddle) by moving it with your hand.
  5. How to Adjust the Truss Rod on an Acoustic Guitar: paso 5, imagen 1 de 1
    • Using your eyes or a metal ruler, check the distance from the strings to the frets on the neck.
    • You can use a metal ruler to measure out approximately 2.5 mm for an acoustic guitar, depending on your preference.
  6. How to Adjust the Truss Rod on an Acoustic Guitar: paso 6, imagen 1 de 1
    • Using the Allen Wrench, make any final adjustments to the truss while the strings are at tension.
    • You may use a tuner to help adjust the strings to the desired tension
  7. How to Adjust the Truss Rod on an Acoustic Guitar: paso 7, imagen 1 de 2 How to Adjust the Truss Rod on an Acoustic Guitar: paso 7, imagen 2 de 2
    • Replace the truss rod cover.
    • Re-tune the guitar.
Conclusión
Reattach the truss rod cover to the headstock of your guitar using the 2 x 1/4 “ Phillips screws and Phillips 0 screwdriver.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 48
Todo El Tiempo: 2,023
