Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Adjust a Piano Key Slip
Qué necesitas
    1. How to Adjust a Piano Key Slip, How to Adjust a Piano Key Slip: paso 1, imagen 1 de 3 How to Adjust a Piano Key Slip, How to Adjust a Piano Key Slip: paso 1, imagen 2 de 3 How to Adjust a Piano Key Slip, How to Adjust a Piano Key Slip: paso 1, imagen 3 de 3
      • Locate the keys that hold your key slip to the piano.
      • They are typically underneath the piano keyboard and there will be between two and four screws.
      • Check to see what kind of screw it is. In the case of this piano, it is a flathead screw; however there could be a variety of screws.
      Pregunta a FixBot
      Agregar Comentario
    2. How to Adjust a Piano Key Slip: paso 2, imagen 1 de 3 How to Adjust a Piano Key Slip: paso 2, imagen 2 de 3 How to Adjust a Piano Key Slip: paso 2, imagen 3 de 3
      • Remove all the screws from the piano and set them aside.
      Pregunta a FixBot
      Agregar Comentario
    3. How to Adjust a Piano Key Slip: paso 3, imagen 1 de 2 How to Adjust a Piano Key Slip: paso 3, imagen 2 de 2
      • Gently remove your key slip using your hands.
      • The key slip is the piece of wood that sits in front of the keys.
      Pregunta a FixBot
      Agregar Comentario
    4. How to Adjust a Piano Key Slip: paso 4, imagen 1 de 3 How to Adjust a Piano Key Slip: paso 4, imagen 2 de 3 How to Adjust a Piano Key Slip: paso 4, imagen 3 de 3
      • Check for debris under the keys.
      • You can vacuum out dust or remove pieces of paper and other objects that have fallen behind the key slip or through the keys.
      Pregunta a FixBot
      Agregar Comentario
    5. How to Adjust a Piano Key Slip: paso 5, imagen 1 de 3 How to Adjust a Piano Key Slip: paso 5, imagen 2 de 3 How to Adjust a Piano Key Slip: paso 5, imagen 3 de 3
      • Replace your key slip, ensuring that it sits evenly between the two ends of the piano.
      Pregunta a FixBot
      Agregar Comentario
    6. How to Adjust a Piano Key Slip: paso 6, imagen 1 de 3 How to Adjust a Piano Key Slip: paso 6, imagen 2 de 3 How to Adjust a Piano Key Slip: paso 6, imagen 3 de 3
      • Re-screw the key slip onto the piano.
      • Don't tighten the screws all the way down at first. Screw each one in a little bit to make it doesn't become uneven.
      • Go back and tighten the screws to your desired tightness.
      • Check the keys to make sure that the they are no longer sticking, and that the key slip is not too tight.
      Pregunta a FixBot
      Agregar Comentario
    7. How to Adjust a Piano Key Slip: paso 7, imagen 1 de 3 How to Adjust a Piano Key Slip: paso 7, imagen 2 de 3 How to Adjust a Piano Key Slip: paso 7, imagen 3 de 3
      • Check each key to make sure they are no longer sticking.
      • If you were successful, no keys will stick and your key slip will be properly placed!
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Congratulations! Your keys are no longer sticky and if your key slip slips out of place again you now know how to fix it!
2 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 46
Todo El Tiempo: 2,675
