Saltar al contenido principal
How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes
Qué necesitas
  1. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes, How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: paso 1, imagen 1 de 1
    • You will see a cable attached to an Allen bolt.
  2. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: paso 2, imagen 1 de 1
    • Loosen up the bolt with the help of Hex key set.
  3. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: paso 3, imagen 1 de 2 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: paso 3, imagen 2 de 2
    • Now, pull the cable as much as you can.
  4. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: paso 4, imagen 1 de 1
    • Tighten up the bolt while you keep pulling the cable.
  5. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: paso 5, imagen 1 de 2 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: paso 5, imagen 2 de 2
    • To center the caliper for a smooth breaking experience, loosen up the two bolts of the brake situated at top and at bottom.
  6. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: paso 6, imagen 1 de 1
    • Now, put the brake on.
  7. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: paso 7, imagen 1 de 3 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: paso 7, imagen 2 de 3 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: paso 7, imagen 3 de 3
    • While putting the brake on, tighten up both the bolts.
    • You are finished adjusting the brakes!
Linea de Meta
2 personas más completaron esta guía.
Un comentario
Dude, the cable is attached incorrectly. The cable routes up and over the little arm.
Grandy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 40
Ultimos 30 días: 204
Todo El Tiempo: 4,446
