Saltar al contenido principal
How to Adjust Cantilever Bicycle Brakes
Qué necesitas
  1. How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: paso 1, imagen 1 de 3 How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: paso 1, imagen 2 de 3 How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: paso 1, imagen 3 de 3
    • Lift bicycle onto the rear wheel by holding the handlebars.
    • Roll the rear wheel forward while placing the handlebars on the ground so that the bike rests upside down.
  2. How to Adjust Cantilever Bicycle Brakes: paso 2, imagen 1 de 2 How to Adjust Cantilever Bicycle Brakes: paso 2, imagen 2 de 2
    • Identify the brake that is rubbing against the bike rim by spinning each wheel while listening for contact.
    • Identify which brake pad is making contact (left or right).
  3. How to Adjust Cantilever Bicycle Brakes: paso 3, imagen 1 de 3 How to Adjust Cantilever Bicycle Brakes: paso 3, imagen 2 de 3 How to Adjust Cantilever Bicycle Brakes: paso 3, imagen 3 de 3
    • Loosen the 6mm hex screw that is holding the noisy brake to the frame.
    • Make sure not to remove the bolt completely.
  4. How to Adjust Cantilever Bicycle Brakes: paso 4, imagen 1 de 1
    • Shift the brake so that the pad no longer makes contact with the rim.
  5. How to Adjust Cantilever Bicycle Brakes: paso 5, imagen 1 de 2 How to Adjust Cantilever Bicycle Brakes: paso 5, imagen 2 de 2
    • Rotate the bicycle tire to ensure the brake is no longer rubbing against the rim.
    • Keep your fingers free of the spokes while the wheel is spinning!
  6. How to Adjust Cantilever Bicycle Brakes: paso 6, imagen 1 de 2 How to Adjust Cantilever Bicycle Brakes: paso 6, imagen 2 de 2
    • Hold the brake in the new position where it no longer rubs.
    • Use the 6 mm hex key to tighten the brake bolt back on.
  7. How to Adjust Cantilever Bicycle Brakes: paso 7, imagen 1 de 2 How to Adjust Cantilever Bicycle Brakes: paso 7, imagen 2 de 2
    • Rotate the wheel again to ensure the brake did not change positions while you were tightening it.
  8. How to Adjust Cantilever Bicycle Brakes: paso 8, imagen 1 de 1
    • Flip the bike back onto its wheels.
Conclusión
Go ride your bike!
Una persona más ha completado esta guía.
Devaughantee
Miembro Desde 09/30/20
194 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 27
Todo El Tiempo: 736
