Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Adjust Black and Decker TR1278B Browning Dial
Qué necesitas
  1. How to Adjust Black and Decker TR1278B Browning Dial, Top Cover: paso 1, imagen 1 de 1
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. How to Adjust Black and Decker TR1278B Browning Dial: paso 2, imagen 1 de 1
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
  3. How to Adjust Black and Decker TR1278B Browning Dial: paso 3, imagen 1 de 1
    • Detach the bottom from the front cover using the plastic opening tool.
  4. How to Adjust Black and Decker TR1278B Browning Dial: paso 4, imagen 1 de 1
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  5. How to Adjust Black and Decker TR1278B Browning Dial: paso 5, imagen 1 de 1
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
  6. How to Adjust Black and Decker TR1278B Browning Dial, How to Adjust Black and Decker TR1278B Browning Dial: paso 6, imagen 1 de 2 How to Adjust Black and Decker TR1278B Browning Dial, How to Adjust Black and Decker TR1278B Browning Dial: paso 6, imagen 2 de 2
    • Remove the front cover.
  7. How to Adjust Black and Decker TR1278B Browning Dial: paso 7, imagen 1 de 2 How to Adjust Black and Decker TR1278B Browning Dial: paso 7, imagen 2 de 2
    • Unscrew the circuit behind the browning dial on the front cover.
    • Do not lose the washers on the screws.
  8. How to Adjust Black and Decker TR1278B Browning Dial: paso 8, imagen 1 de 1
    • Remove the circuit.
    • The dial and buttons on the front cover will be loose.
  9. How to Adjust Black and Decker TR1278B Browning Dial: paso 9, imagen 1 de 1
    • Turn the knob on the circuit board left or right to adjust the browning dial.
Conclusión
Dominic Gamonez
Miembro Desde 02/15/17
257 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 8-1, Eyestone Spring 2017 Miembro de USF Tampa, Team 8-1, Eyestone Spring 2017
USFT-EYESTONE-S17S8G1
Miembros de 3
5 Guías creadas
1Guía Comentario
In step 9 you are missing the plastic piece that goes into the hole next to the cancel button to index the position of the knob. No screws go in that spot.
Mr. S - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 28
Todo El Tiempo: 971
