Saltar al contenido principal
How to Access the Insides of a Patagonia Down Jacket
Qué necesitas
  1. How to Access the Insides of a Patagonia Down Jacket, How to Access the Insides of a Patagonia Down Jacket: paso 1, imagen 1 de 2 How to Access the Insides of a Patagonia Down Jacket, How to Access the Insides of a Patagonia Down Jacket: paso 1, imagen 2 de 2
    • Unzip your Patagonia jacket.
    • Examine the area of your jacket that needs a patch. If your jacket has a lining, or the area that needs repair does not have baffle stitches and pulls away from the front of the jacket, follow this guide.
    • If the area of the jacket that needs repair is not lined, check our our Baffle Repair Guide.
  2. How to Access the Insides of a Patagonia Down Jacket: paso 2, imagen 1 de 2 How to Access the Insides of a Patagonia Down Jacket: paso 2, imagen 2 de 2
    • Find the closest seam to the area that needs repair. In our case, it’s the bottom seam of the jacket.
    • Using a seam ripper, gently pull out the visible stitches on the seam.
    • Seam rippers are sharp, and it’s easy to puncture or tear the fabric of the jacket. Be sure you’re only ripping the stitches and not the jacket itself. Take your time.
  3. How to Access the Insides of a Patagonia Down Jacket: paso 3, imagen 1 de 2 How to Access the Insides of a Patagonia Down Jacket: paso 3, imagen 2 de 2
    • Rip the seam until you have ripped several inches of seam on either side of the hole. Then continue ripping in the direction of the nearest perpendicular seam. In the case illustrated here, it’s the zipper seam.
    • With this seam ripped, you should see the baffles inside of the jacket.
  4. How to Access the Insides of a Patagonia Down Jacket: paso 4, imagen 1 de 2 How to Access the Insides of a Patagonia Down Jacket: paso 4, imagen 2 de 2
    • Identify the stitching in the nearest perpendicular seam. In this case, it’s the seam where the lining meets the fabric for the zipper flap.
  5. How to Access the Insides of a Patagonia Down Jacket: paso 5, imagen 1 de 2 How to Access the Insides of a Patagonia Down Jacket: paso 5, imagen 2 de 2
    • Rip this seam until the seam opening is three to five inches past the area that needs to be repaired.
    • In this case, we are ripping about halfway up the jacket.
  6. How to Access the Insides of a Patagonia Down Jacket: paso 6, imagen 1 de 3 How to Access the Insides of a Patagonia Down Jacket: paso 6, imagen 2 de 3 How to Access the Insides of a Patagonia Down Jacket: paso 6, imagen 3 de 3
    • Using the seam ripper, remove the bottom satin stitching to free the lining.
    • This step isn’t necessary on all jackets. If your lining comes free without removing these stitches, omit this step.
  7. How to Access the Insides of a Patagonia Down Jacket: paso 7, imagen 1 de 3 How to Access the Insides of a Patagonia Down Jacket: paso 7, imagen 2 de 3 How to Access the Insides of a Patagonia Down Jacket: paso 7, imagen 3 de 3
    • Insert the seam ripper between the two pieces of fabric and carefully rip any stitches between them that may hold the fabrics together.
    • Take care that you only rip the stitches and not the garment!
  8. How to Access the Insides of a Patagonia Down Jacket: paso 8, imagen 1 de 2 How to Access the Insides of a Patagonia Down Jacket: paso 8, imagen 2 de 2
    • Fold back the lining so it stays clear of the area that needs repair.
  9. How to Access the Insides of a Patagonia Down Jacket: paso 9, imagen 1 de 3 How to Access the Insides of a Patagonia Down Jacket: paso 9, imagen 2 de 3 How to Access the Insides of a Patagonia Down Jacket: paso 9, imagen 3 de 3
    • If your jacket has a pocket, make sure the two tabs holding the pocket in place are free.
    • If the tabs aren’t free, rip any stitches remaining to free them.
    • Fold the pocket away from the area that needs repair.
    • When reassembling your garment, be sure to catch the two pocket tabs in the seam.
  10. How to Access the Insides of a Patagonia Down Jacket: paso 10, imagen 1 de 2 How to Access the Insides of a Patagonia Down Jacket: paso 10, imagen 2 de 2
    • Unless the repair is at the very bottom edge of the garment, leave the drawcord intact. If you can work around it, it will be easier than removing it and sewing it back into place.
    • When reassembling your jacket, try to sew over the existing holes to keep from creating new openings which might allow down to escape. If possible, steam your jacket once you have finished the repair. This will help close any stitching holes and prevent additional loss of the down material.
Conclusión
To reassemble your jacket, follow these instructions in reverse order.
4 personas más completaron esta guía.
Brittany McCrigler
Miembro Desde 03/05/12
89,965 Reputación
142 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 121
19,763 Guías creadas
3Guía Comentarios
Does this have to be hand sewn back up? Is it just the basic handsewing stitch? It feel like the sewing up of the garment is just as challenging if not more than the seam-ripping of it. From this guide, I'm not at all confident about how to put my coat back together again - which has me be very wary of ripping the seams to take it apart. Please help! Thanks!
Byron Go - Contestar
Great question Byron! You can either hand-sew or machine stitch your jacket back together. If you hand sew, you'll want to use a straight stitch (guide here: Sew a Straight Stitch). If you machine sew, be sure to use a very sharp needle in your machine. You will also probably want to use some sewing clips (like these: https://www.amazon.com/Clover-Wonder-Cli...) to hold the garment together while you sew it up, instead of pins that will create more little holes. In either case, take your time, as the material is very slippery. You will also want to follow the guide backwards to ensure you have the layers in the right positions and order. Good luck on your repair—you got this!
Brittany McCrigler -
👏 Great guide on accessing the insides of a Patagonia down jacket! The step-by-step instructions are clear and helpful. For those worried about reassembly, hand-sewing or machine stitching with a sharp needle should do the trick. Remember to take your time and use sewing clips instead of pins. Happy repairing! 🧵🧥
fawwad qureshi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 20
Ultimos 30 días: 88
Todo El Tiempo: 16,604
