Saltar al contenido principal
Safely remove PC case stickers
Qué necesitas
  1. Safely remove PC case stickers, Remove the battery (Laptops only): paso 1, imagen 1 de 2 Safely remove PC case stickers, Remove the battery (Laptops only): paso 1, imagen 2 de 2
    • The procedure to remove the battery is specific to every laptop.
    • Before removing the stickers, remove the battery.
  2. Safely remove PC case stickers, Warm up the adhesive: paso 2, imagen 1 de 3 Safely remove PC case stickers, Warm up the adhesive: paso 2, imagen 2 de 3 Safely remove PC case stickers, Warm up the adhesive: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    iFixit Opening Picks (Set of 6)
    Comprar
    • 30-60 seconds of heat is sufficient.
    • If the sticker is thin, a guitar pick may help.
    • After removing the battery, warm up the palmrest with a hairdryer until it is warm to the touch.
    • Peel the stickers off.
  3. Safely remove PC case stickers, Clean the remaining glue: paso 3, imagen 1 de 3 Safely remove PC case stickers, Clean the remaining glue: paso 3, imagen 2 de 3 Safely remove PC case stickers, Clean the remaining glue: paso 3, imagen 3 de 3
    • While denatured alchol works, it may "strip" some rubber coatings and paint! Use good judgement!
    • After the sticker(s) have been removed, clean the residual glue with a small amount of gentle solvent.
    • Clean the solvent after a few seconds.
Linea de Meta
6 personas más completaron esta guía.
Nick
Miembro Desde 11/10/09
88,419 Reputación
49 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,506 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 30
Ultimos 30 días: 154
Todo El Tiempo: 15,575
