Saltar al contenido principal
How do I wash and dry my Vaude membrane jacket or trousers?
Qué necesitas
  1. How do I wash and dry my Vaude membrane jacket or trousers?, Read the care label on the product: paso 1, imagen 1 de 3 How do I wash and dry my Vaude membrane jacket or trousers?, Read the care label on the product: paso 1, imagen 2 de 3 How do I wash and dry my Vaude membrane jacket or trousers?, Read the care label on the product: paso 1, imagen 3 de 3
    • Set the washing machine to 30 °C with a gentle cycle. There are symbols for the recommended care products on the smaller label. We recommend Nikwax Tech Wash for the washing cycle and TX Direct Spray from Nikwax for waterproofing if necessary.
    • Details to the care symbols for washing, bleaching, drying or ironing you will find here: http://help.vaude.com/care-instructions/...
  2. How do I wash and dry my Vaude membrane jacket or trousers?: paso 2, imagen 1 de 1
    • Fill the washing machine. For optimal results you should wash similar colours together.
    • Please always close buttons, zippers and Velcro closures before washing. This keeps fibers from catching and the clothing from stretching out during the wash cycle.
  3. How do I wash and dry my Vaude membrane jacket or trousers?, Washing: paso 3, imagen 1 de 2 How do I wash and dry my Vaude membrane jacket or trousers?, Washing: paso 3, imagen 2 de 2
    • Set the washing machine to the cycle and temperature recommended on the apparel. In our example it is 30 °C and a gentle cycle. Put the correct amount of liquid in the dispenser depending on the hardness of your water. You can find out how much you should use by reading the instructions on the care product.
    • Do not use fabric softener or bleach!
  4. How do I wash and dry my Vaude membrane jacket or trousers?, Drying: paso 4, imagen 1 de 1
    • For optimal reactivation of the waterproofing (DWR), put the clothing into the dryer for 30 to 50 minutes after washing
    • Alternatively, you can air dry the clothing in a warm and dry place, however, the waterproofing will not be reactivated.
  5. How do I wash and dry my Vaude membrane jacket or trousers?, Waterproofing if necessary: paso 5, imagen 1 de 1
    • When your jacket is dry, you can do a water beading test to find out if you need to re-waterproof it. Water should pearl up into beads on the surface of the jacket. To waterproof, we recommend TX-Direct Spray from Nikwax. Spray the outside of the clothing evenly. This leaves the inside untreated to that it can absorb moisture and move it outward.
    • Please follow the instructions printed on the care product.
Linea de Meta
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
de en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
VAUDE Reparaturteam
Miembro Desde 02/22/16
6,186 Reputación
32 Guías creadas
Equipo
Vaudesport Miembro de Vaudesport
Community
3 Miembros
96 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 67
Todo El Tiempo: 1,887
