Saltar al contenido principal
How To Replace Burners on Weber Genesis II Grill
Qué necesitas
  1. How To Replace Burners on Weber Genesis II Grill, Burners: paso 1, imagen 1 de 3 How To Replace Burners on Weber Genesis II Grill, Burners: paso 1, imagen 2 de 3 How To Replace Burners on Weber Genesis II Grill, Burners: paso 1, imagen 3 de 3
    • This is the Weber Genesis II grill. Before replacement of the burner, we will start by cleaning the grates with a grill brush in order to be clean and safe.
    • Make sure that the grill is completely turned off so there is no chance of accidental burn.
  2. How To Replace Burners on Weber Genesis II Grill: paso 2, imagen 1 de 3 How To Replace Burners on Weber Genesis II Grill: paso 2, imagen 2 de 3 How To Replace Burners on Weber Genesis II Grill: paso 2, imagen 3 de 3
    • Remove the grates using your hands.
    • Grab on each side of the grill grate with your hands and lift straight upwards.
    • Set the removed grate off to the side of the grill.
    • Repeat this procedure for all three of the grates on top of the grill.
  3. How To Replace Burners on Weber Genesis II Grill: paso 3, imagen 1 de 3 How To Replace Burners on Weber Genesis II Grill: paso 3, imagen 2 de 3 How To Replace Burners on Weber Genesis II Grill: paso 3, imagen 3 de 3
    • Remove the heat deflector plates from on top of the burners.
    • Grab each deflector plate and pull straight upwards as with the grates.
    • Place the removed heat deflector plates off to the side of the grill.
    • Repeat this procedure for all heat deflector plates until each burner is exposed.
    • Only half of the heat deflectors plates will have burners underneath them. So do not be alarmed when not all plates have a burner.
  4. How To Replace Burners on Weber Genesis II Grill: paso 4, imagen 1 de 3 How To Replace Burners on Weber Genesis II Grill: paso 4, imagen 2 de 3 How To Replace Burners on Weber Genesis II Grill: paso 4, imagen 3 de 3
    • Remove the burner from its slot in the back of the grill.
    • With both hands, carefully pull the burner upwards and slightly to the left in order to pull it out of its slot.
    • The burners can become stuck and require a little extra force to pull out, but do not pull too hard and hit the top of the grill or yourself.
    • If replacing all burners, repeat this procedure to remove all burners from their slots.
  5. How To Replace Burners on Weber Genesis II Grill: paso 5, imagen 1 de 3 How To Replace Burners on Weber Genesis II Grill: paso 5, imagen 2 de 3 How To Replace Burners on Weber Genesis II Grill: paso 5, imagen 3 de 3
    • Detach the burner from the ignition device.
    • With a small wedge, such as a flat-head screwdriver, unclip the white connector from the burner.
    • With the ignition device removed, you are now all set to replace the burner with a new one.
Conclusión
2 personas más completaron esta guía.
Nicholas Brown
Miembro Desde 03/24/21
175 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 63
Ultimos 30 días: 313
Todo El Tiempo: 8,795
