Saltar al contenido principal
How To Repair An Overheating D-LINK DIR-655 Wireless Router
Qué necesitas
  1. How To Repair An Overheating D-LINK DIR-655 Wireless Router, How To Repair An Overheating D-LINK DIR-655 Wireless Router: paso 1, imagen 1 de 2 How To Repair An Overheating D-LINK DIR-655 Wireless Router, How To Repair An Overheating D-LINK DIR-655 Wireless Router: paso 1, imagen 2 de 2
    • Start by removing the three antennas by twisting each one in a counter-clockwise direction when facing the back panel.
  2. How To Repair An Overheating D-LINK DIR-655 Wireless Router: paso 2, imagen 1 de 2 How To Repair An Overheating D-LINK DIR-655 Wireless Router: paso 2, imagen 2 de 2
    • Using your flathead screwdriver or plastic opening tool, gently pry the top two screw covers out of the router's case.
  3. How To Repair An Overheating D-LINK DIR-655 Wireless Router: paso 3, imagen 1 de 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: paso 3, imagen 2 de 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: paso 3, imagen 3 de 3
    • Using your Phillips screwdriver, turn the screw counter-clockwise to remove it from the assembly.
    • Do the same for the second screw.
  4. How To Repair An Overheating D-LINK DIR-655 Wireless Router: paso 4, imagen 1 de 1
    • Gently pry the top of the case from the sides and bottom of the router.
    • After freeing the top, remove it and set it aside.
  5. How To Repair An Overheating D-LINK DIR-655 Wireless Router: paso 5, imagen 1 de 2 How To Repair An Overheating D-LINK DIR-655 Wireless Router: paso 5, imagen 2 de 2
    • With your Phillips screwdriver, remove both screws by rotating in a counter-clockwise direction.
  6. How To Repair An Overheating D-LINK DIR-655 Wireless Router: paso 6, imagen 1 de 1
    • After removing the screws, lift the white LED cover up and off of the circuit board.
  7. How To Repair An Overheating D-LINK DIR-655 Wireless Router: paso 7, imagen 1 de 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: paso 7, imagen 2 de 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: paso 7, imagen 3 de 3
    • Next, bend up the clip holding down the middle antenna wire.
    • Gently, unhook the wire and move it out of the way.
  8. How To Repair An Overheating D-LINK DIR-655 Wireless Router: paso 8, imagen 1 de 1
    • With the wire out of the way, separate the circuit board from the bottom assembly.
    • Be sure not to pinch or bend the antenna wire when you lift the circuit board.
  9. How To Repair An Overheating D-LINK DIR-655 Wireless Router: paso 9, imagen 1 de 1
    • Wipe away any dust from the the vents to ensure proper airflow.
Conclusión
6 personas más completaron esta guía.
Chance Daniel
Miembro Desde 09/29/15
263 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 10-6, Green Fall 2015 Miembro de Cal Poly, Team 10-6, Green Fall 2015
CPSU-GREEN-F15S10G6
3 Miembros
3 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 31
Todo El Tiempo: 5,458
