Introducción
In this guide we will be learning how to remove a headliner from a 2002 Dodge Dakota. We will be removing the visor, the visor clips, rear ceiling clips, the rear light, the center light, and the side panel. Please read and follow all instructions, and no parts will be damaged, and you will be able to successfully remove the headliner. Good luck and have fun!
Qué necesitas
Remove the two Phillips #0 screws on the two visor mounts on either side of the cab.
Remove the seatbelt cover. This is held by two mini clips on either side of the cap. They are flexible so you could just pry the cap off, but if wanted, use your flathead screwdriver to poke the clips out of place and remove the capping.
This panel has 3 clips very similar to the rear tabs highlighted in step 5, as well as one big screw.
Use either a big Allen wrench or a pipe wrench to remove the big screw under the capping.
Gently pry each corner of the panel away from the wall to disengage each of the 3 clips, and the panel will pop out.
Una persona más ha completado esta guía.
