Saltar al contenido principal
How To Patch A Hole In The Wall
Qué necesitas
  1. How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: paso 1, imagen 1 de 3 How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: paso 1, imagen 2 de 3 How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: paso 1, imagen 3 de 3
    • Sand down the hole and the area surrounding. This is in order to get paint off the wall.
  2. How To Patch A Hole In The Wall: paso 2, imagen 1 de 2 How To Patch A Hole In The Wall: paso 2, imagen 2 de 2
    • Use the rag and the toothbrush to clean off any excess rubble near the hole.
  3. How To Patch A Hole In The Wall: paso 3, imagen 1 de 1
    • Follow the directions on the spackle box to prepare the spackle for application.
    • Although all spackle brands are different, spackle should have a consistency similar to toothpaste when mixed with water.
  4. How To Patch A Hole In The Wall: paso 4, imagen 1 de 3 How To Patch A Hole In The Wall: paso 4, imagen 2 de 3 How To Patch A Hole In The Wall: paso 4, imagen 3 de 3
    • Take the spackle mix and apply it to the hole.
    • Make sure to layer the spackle evenly and remove excess spackle.
  5. How To Patch A Hole In The Wall: paso 5, imagen 1 de 1
    • Wait 30-45 minutes for the spackle patch to dry.
    • Wait time may vary depending on the depth of the hole and spackle mix used.
  6. How To Patch A Hole In The Wall: paso 6, imagen 1 de 1
    • Make sure the spackle is dry.
    • Sand the spackle until it is smooth and flush with the wall.
Conclusión
Now your wall should be looking as good as new!
3 personas más completaron esta guía.
Joseph Garcia
Miembro Desde 09/29/15
293 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 17-2, Green Fall 2015 Miembro de Cal Poly, Team 17-2, Green Fall 2015
CPSU-GREEN-F15S17G2
4 Miembros
8 Guías creadas
Un comentario
I suggest using a sanding sponge or block in step 6
Dennis - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 22
Todo El Tiempo: 1,240
