Saltar al contenido principal
How To Fix a Jammed Box Cutter
Qué necesitas
  1. How To Fix a Jammed Box Cutter, How To Fix a Jammed Box Cutter: paso 1, imagen 1 de 3 How To Fix a Jammed Box Cutter, How To Fix a Jammed Box Cutter: paso 1, imagen 2 de 3 How To Fix a Jammed Box Cutter, How To Fix a Jammed Box Cutter: paso 1, imagen 3 de 3
    • Using a Phillips head screwdriver, unscrew the screw on the box cutter.
    • Remove the top part of the box cutter.
  2. How To Fix a Jammed Box Cutter: paso 2, imagen 1 de 3 How To Fix a Jammed Box Cutter: paso 2, imagen 2 de 3 How To Fix a Jammed Box Cutter: paso 2, imagen 3 de 3
    • Caution: Sharp Object Involved
    • Pick up the blade.
    • Separate the blade from the trigger.
  3. How To Fix a Jammed Box Cutter: paso 3, imagen 1 de 3 How To Fix a Jammed Box Cutter: paso 3, imagen 2 de 3 How To Fix a Jammed Box Cutter: paso 3, imagen 3 de 3
    • Look for the sliding bar and circle which will be located towards the end of the box cutter.
    • Place the trigger aligning with the sliding bar and the circle in the middle of the box cutter.
    • Apply pressure with your finger onto the magnetic part of the trigger to secure placement.
  4. How To Fix a Jammed Box Cutter: paso 4, imagen 1 de 2 How To Fix a Jammed Box Cutter: paso 4, imagen 2 de 2
    • Carefully pick up the blade and identify the left hook of the blade and identify the hook of the trigger.
    • Align the hook from the blade on top of the trigger hook.
  5. How To Fix a Jammed Box Cutter: paso 5, imagen 1 de 2 How To Fix a Jammed Box Cutter: paso 5, imagen 2 de 2
    • Place the box cutter back together.
  6. How To Fix a Jammed Box Cutter: paso 6, imagen 1 de 2 How To Fix a Jammed Box Cutter: paso 6, imagen 2 de 2
    • Hand tightly screw the screw back into the box cutter.
    • Finish off screwing the screw into the box cutter with the screw driver.
Conclusión
Yailene
Miembro Desde 10/23/23
133 Reputación
1 Guía escrita
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 33
Ultimos 30 días: 161
Todo El Tiempo: 2,294
