Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How To Fix a Broken Wreath
Qué necesitas
  1. How To Fix a Broken Wreath, How To Fix a Broken Wreath: paso 1, imagen 1 de 3 How To Fix a Broken Wreath, How To Fix a Broken Wreath: paso 1, imagen 2 de 3 How To Fix a Broken Wreath, How To Fix a Broken Wreath: paso 1, imagen 3 de 3
    • Use floral wire to repair the base by wrapping it around the affected area.
    • Reattach the hanger while wrapping your base with floral wire.
    • Use hot glue for additional security if needed.
  2. How To Fix a Broken Wreath: paso 2, imagen 1 de 3 How To Fix a Broken Wreath: paso 2, imagen 2 de 3 How To Fix a Broken Wreath: paso 2, imagen 3 de 3
    • Wrap any missing branches with floral wire.
    • Use hot glue to reattach the branches to the base.
  3. How To Fix a Broken Wreath: paso 3, imagen 1 de 3 How To Fix a Broken Wreath: paso 3, imagen 2 de 3 How To Fix a Broken Wreath: paso 3, imagen 3 de 3
    • Wrap the base of the decoration with floral wire and wrap around the base.
    • Use hot glue to secure in place, but be careful to avoid melting any plastic.
  4. How To Fix a Broken Wreath: paso 4, imagen 1 de 3 How To Fix a Broken Wreath: paso 4, imagen 2 de 3 How To Fix a Broken Wreath: paso 4, imagen 3 de 3
    • Use your glue gun to attach any other pieces that do not require floral wire to be attached, such as berries.
  5. How To Fix a Broken Wreath: paso 5, imagen 1 de 1
    • Add any final touches that you wish to add. If the pieces attached are oddly colored, you may choose to spray them with craft snow or glitter to give them an even look.
    • Check over your wreath, add hot glue to any areas that need extra security.
    • Hang finished wreath up for decoration.
Linea de Meta
Kimberly Lammers
Miembro Desde 11/26/21
133 Reputación
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 27
Todo El Tiempo: 851
