Saltar al contenido principal
How To Fix Misaligned Bicycle Handlebars
Qué necesitas
  1. How To Fix Misaligned Bicycle Handlebars, How To Fix Misaligned Bicycle Handlebars: paso 1, imagen 1 de 2 How To Fix Misaligned Bicycle Handlebars, How To Fix Misaligned Bicycle Handlebars: paso 1, imagen 2 de 2
    • Stand with your bicycle in front of you.
    • Put your front wheel between your legs.
  2. How To Fix Misaligned Bicycle Handlebars: paso 2, imagen 1 de 1
    • Hold the bike's front wheel tight with your legs to keep the bike upright.
    • Grab the handlebar and make it perpendicular to the front wheel.
    • Keep your bike stable at all times.
  3. How To Fix Misaligned Bicycle Handlebars: paso 3, imagen 1 de 3 How To Fix Misaligned Bicycle Handlebars: paso 3, imagen 2 de 3 How To Fix Misaligned Bicycle Handlebars: paso 3, imagen 3 de 3
    • Loosen the stem using the Allen wrench. Do minor adjustments using your hand.
    • Put the handlebar in a straight position. Then use a ruler, tape measure, or adjust by sight to the correct placement.
  4. How To Fix Misaligned Bicycle Handlebars: paso 4, imagen 1 de 2 How To Fix Misaligned Bicycle Handlebars: paso 4, imagen 2 de 2
    • DO NOT move your handle bars when you are adjusting the position.
    • Use the Allen wrench or Hex key to gently turn the two bolts (some bikes have one) on the stem until they hold tight.
  5. How To Fix Misaligned Bicycle Handlebars: paso 5, imagen 1 de 1
    • After tightening the bolt(s), check the alignment again.
    • Now, try rotating your bike using handlebar.
    • If it's still loose that means you may need to replace the handlebar.
  6. How To Fix Misaligned Bicycle Handlebars: paso 6, imagen 1 de 1
    • If your handlebar works as expected you can ride your bike now.
    • Have a safe trip!
Conclusión
Using this guide will help you easily fix your handlebar.
Documentos Adjuntos
Telmuun
Miembro Desde 09/07/21
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 12
Ultimos 7 días: 84
Ultimos 30 días: 343
Todo El Tiempo: 13,174
