Saltar al contenido principal
How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan
Qué necesitas
  1. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan, How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: paso 1, imagen 1 de 1
    • remove the three Phillips screws under the fan closest to the video ports of the card
  2. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: paso 2, imagen 1 de 1
    • Lift the fan out(will be attached to a small cord but gets out of the way well) and shim a small cushion under the center circle, between the aluminum cooling fins and the plastic. I used electric tape, rolling it, sticky side in, to form about a 6 layer small square of tape. It shimmed in nicely.
  3. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: paso 3, imagen 1 de 1
    • Reassemble and re-install the card into your computer. It should stop the vibration.
Conclusión
8 personas más completaron esta guía.
Un comentario
Can you post a picture showing how its fit in the fins?
Gustavo Horta - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 8,346
