1. remove the three Phillips screws under the fan closest to the video ports of the card
    • remove the three Phillips screws under the fan closest to the video ports of the card
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Lift the fan out(will be attached to a small cord but gets out of the way well)  and shim a small cushion under the center circle, between the aluminum cooling fins and the plastic. I used electric tape, rolling it, sticky side in, to form about a 6 layer small square of tape. It shimmed in nicely.
    • Lift the fan out(will be attached to a small cord but gets out of the way well) and shim a small cushion under the center circle, between the aluminum cooling fins and the plastic. I used electric tape, rolling it, sticky side in, to form about a 6 layer small square of tape. It shimmed in nicely.
  4. Reassemble and re-install the card into your computer. It should stop the vibration.
    • Reassemble and re-install the card into your computer. It should stop the vibration.
Conclusión
8 personas más completaron esta guía.
Can you post a picture showing how its fit in the fins?
Gustavo Horta - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 7
Últimos 30 Días: 30
Todo El Tiempo: 7,350
