Saltar al contenido principal
How To Do An Oil Change With An Oil Extractor/Pump
Qué necesitas
  1. How To Do An Oil Change With An Oil Extractor/Pump, How To Do An Oil Change With An Oil Extractor/Pump: paso 1, imagen 1 de 2 How To Do An Oil Change With An Oil Extractor/Pump, How To Do An Oil Change With An Oil Extractor/Pump: paso 1, imagen 2 de 2
    • Open the engine bay and locate the oil filter, oil fill hole, and dipstick/oil suction hole.
    • Remove the engine cover if necessary.
  2. How To Do An Oil Change With An Oil Extractor/Pump: paso 2, imagen 1 de 2 How To Do An Oil Change With An Oil Extractor/Pump: paso 2, imagen 2 de 2
    • Remove the oil suction plug or dipstick.
    • Break loose the filter or filter cap.
  3. How To Do An Oil Change With An Oil Extractor/Pump: paso 3, imagen 1 de 3 How To Do An Oil Change With An Oil Extractor/Pump: paso 3, imagen 2 de 3 How To Do An Oil Change With An Oil Extractor/Pump: paso 3, imagen 3 de 3
    • Insert the pump tube into the fill hole/dipstick hole. Continue to feed until the tube hits the bottom.
    • Attach positive and negative alligator clips onto the battery terminal
    • This is not necessary if you’re using a manual pump.
    • Start the suction motor by flipping the "On" switch and start collecting the used oil into a container.
    • For manual pumps, start pumping.
    • The referenced vehicle has a trunk mounted battery. There is also an extended positive terminal to the front (circled in orange on the right side of photo 2 of step 3) If no negative terminal is available, secure the ground clip to exposed metal on the vehicle frame or engine block.
  4. How To Do An Oil Change With An Oil Extractor/Pump: paso 4, imagen 1 de 3 How To Do An Oil Change With An Oil Extractor/Pump: paso 4, imagen 2 de 3 How To Do An Oil Change With An Oil Extractor/Pump: paso 4, imagen 3 de 3
    • Break the oil filter loose with a ratchet or filter wrench.
    • If the filter has a housing, remove the filter assembly and replace the filter inside.
    • Replace the O-ring. (A screwdriver may make this process easier.) Make sure the O-ring goes back into the same slot as before and lubricate it with some oil.
    • If your oil filter does not reuse the housing, skip these steps and go straight to lubricating the O ring on the new filter.
    • Brake clean can be used to clean the inside of the housing but it is not necessary.
  5. How To Do An Oil Change With An Oil Extractor/Pump: paso 5, imagen 1 de 3 How To Do An Oil Change With An Oil Extractor/Pump: paso 5, imagen 2 de 3 How To Do An Oil Change With An Oil Extractor/Pump: paso 5, imagen 3 de 3
    • After lubrication, hand tighten the filter into the slot.
    • Using a torque wrench, torque the filter to manufacturer's specification
    • For the vehicle referenced, torque specification is 25-foot pounds (about 32 newton meters).
  6. How To Do An Oil Change With An Oil Extractor/Pump: paso 6, imagen 1 de 3 How To Do An Oil Change With An Oil Extractor/Pump: paso 6, imagen 2 de 3 How To Do An Oil Change With An Oil Extractor/Pump: paso 6, imagen 3 de 3
    • Unscrew the oil filler cap and add oil to manufacturer’s specification. Oil capacity can usually be found in vehicle user manuals. If necessary, use a funnel to limit splash.
    • Use the dipstick to check the oil level. Make sure the car is on a level surface.
Conclusión
Start the vehicle, check for leaks, and ensure the oil pressure is within normal range if a gauge is available.
Documentos Adjuntos
Ryan Wu
Miembro Desde 09/17/21
183 Reputación
1 Guía escrita
Equipo
Un comentario
For cars with no dip stick, can the suction tube be sent down the hole of the oil cartridge once the filter is removed? Or down the filler cap?
Vinsk - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 46
Ultimos 30 días: 205
Todo El Tiempo: 6,739
