Saltar al contenido principal
Hoverboard Bluetooth Remote Control Replacement
Qué necesitas
  1. Hoverboard Bluetooth Remote Control Replacement, Bluetooth Remote Control: paso 1, imagen 1 de 1
    • Remove the 10 screws with a Phillips screwdriver to access the inside of the hoverboard.
    • The electronic circuit boards are mirrored on both sides, so examine them both to determine which has the Bluetooth setup.
  2. Hoverboard Bluetooth Remote Control Replacement: paso 2, imagen 1 de 1
    • Unhook the lighting and indicator light wires to remove the cover.
  3. Hoverboard Bluetooth Remote Control Replacement: paso 3, imagen 1 de 1
    • Remove the 4 screws that hold the circuit board support.
  4. Hoverboard Bluetooth Remote Control Replacement: paso 4, imagen 1 de 1
    • Remove the 4 screws that secure the board to the support.
  5. Hoverboard Bluetooth Remote Control Replacement: paso 5, imagen 1 de 1
    • Remember the sequence of wires to be soldered on the Bluetooth board.
  6. Hoverboard Bluetooth Remote Control Replacement: paso 6, imagen 1 de 1
    • Use a soldering iron to affix the 4 pins of the Bluetooth board onto the hoverboard board
    • Before soldering the boards, check the functionality of the Bluetooth board by merely inserting the pins, which is enough.
Conclusión
To reassemble your device, Follow these instructions in reverse order.
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
it en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Smilzo
Miembro Desde 11/09/13
11,267 Reputación
39 Guías creadas
4 comentarios
Hello! Would it be possible to know where to get that bluetooth module? I would like to try that one my hoverboard but cant find the needed part.
Nix Mathy - Contestar
Ciao,puoi cercare su EBay AliExpress Wish ed altri store cinesi
Smilzo -
Well after 5 days of search on ali.. ebay.. bangood.. amazon. I still haven't found the good part.
I've ask a lots of sellers and they all replied the module they sell is only for music no app control :(
Nix Mathy -
Nix Mathy devi cercare bene come parola chiave.io li vedo su tanti store
telecomando self balance hoverboard
https://www.amazon.it/Hoverboard-Telecom...
https://www.ebay.it/itm/REPLACEMENT-REMO...
Smilzo -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 30
Todo El Tiempo: 1,111
