Saltar al contenido principal
Introducción
Is your Hover-1 Ultra not charging to full battery, or not powering up at all? If you are experiencing these problems, it can be fixed with a very simple replacement of the charging port of your device. You will need a Phillips #1 screwdriver to remove the screws and an adjustable crescent wrench to remove the port
Partes
No se especificaron partes.
  1. Orient the hoverboard so that the pads are facing down. With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the board. Carefully remove the shell, lifting directly up.
    • Orient the hoverboard so that the pads are facing down.
    • With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the board.
    • Carefully remove the shell, lifting directly up.
  2. Using your hands or a crescent wrench, begin removing the charging port. Turn the charging port counter-clockwise to release it from the shell.
    • Using your hands or a crescent wrench, begin removing the charging port.
    • Turn the charging port counter-clockwise to release it from the shell.
  3. Unclip the insulated red and black wires  attached to the port from the motherboard Unclip the insulated red and black wires  attached to the port from the motherboard Unclip the insulated red and black wires  attached to the port from the motherboard
    • Unclip the insulated red and black wires attached to the port from the motherboard
  4. Remove the charging port through the assembly. Place new charging port through the assembly. Clip red and black insulated wires into the motherboard.
    • Remove the charging port through the assembly.
    • Place new charging port through the assembly.
    • Clip red and black insulated wires into the motherboard.
Conclusión
To reassemble your device, follow the instructions for step 1 in reverse order.
Una persona más ha completado esta guía.
Camron Clifton
Miembro Desde 22/10/18
331 Reputación
3 Guías creadas
Equipo
UC Davis, Team S7-G5, Lore Fall 2018 Miembro de UC Davis, Team S7-G5, Lore Fall 2018
UCD-LORE-F18S7G5
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 358
