Saltar al contenido principal
Hover-1 Titan Right Gyroscope Replacement
Qué necesitas
  1. Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: paso 1, imagen 1 de 2 Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: paso 1, imagen 2 de 2
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Right Gyroscope Replacement: paso 2, imagen 1 de 2 Hover-1 Titan Right Gyroscope Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Right Gyroscope Replacement: paso 3, imagen 1 de 3 Hover-1 Titan Right Gyroscope Replacement: paso 3, imagen 2 de 3 Hover-1 Titan Right Gyroscope Replacement: paso 3, imagen 3 de 3
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: paso 4, imagen 1 de 2 Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: paso 4, imagen 2 de 2
    • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Right Gyroscope Replacement: paso 5, imagen 1 de 3 Hover-1 Titan Right Gyroscope Replacement: paso 5, imagen 2 de 3 Hover-1 Titan Right Gyroscope Replacement: paso 5, imagen 3 de 3
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
  6. Hover-1 Titan Right Gyroscope Replacement: paso 6, imagen 1 de 2 Hover-1 Titan Right Gyroscope Replacement: paso 6, imagen 2 de 2
    • Unplug the bottom left connector by squeezing it and pulling it away from the board.
  7. Hover-1 Titan Right Gyroscope Replacement: paso 7, imagen 1 de 2 Hover-1 Titan Right Gyroscope Replacement: paso 7, imagen 2 de 2
    • Unplug the white wires by squeezing the connector and pulling away from the board.
  8. Hover-1 Titan Right Gyroscope Replacement: paso 8, imagen 1 de 2 Hover-1 Titan Right Gyroscope Replacement: paso 8, imagen 2 de 2
    • Unplug one set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  9. Hover-1 Titan Right Gyroscope Replacement: paso 9, imagen 1 de 2 Hover-1 Titan Right Gyroscope Replacement: paso 9, imagen 2 de 2
    • Unplug the other set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  10. Hover-1 Titan Right Gyroscope Replacement: paso 10, imagen 1 de 1
    • Cut the cable tie and unplug the remaining wires.
Conclusión
2 personas más completaron esta guía.
Jessica Ouyang
Miembro Desde 10/08/18
619 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S15-G4, White Fall 2018 Miembro de Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Miembros
10 Guías creadas
Un comentario
Where can I get the circuit boards for the left and right ?
jfsucher - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 28
Todo El Tiempo: 1,063
