Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
If your hoverboard will not turn on, retain a charge, move, or spin properly, use this guide to help replace your Hover-1 Titan gyroscope/motherboard.
Partes
No se especificaron partes.
  1. Flip the hoverboard so the bottom is facing up. The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard. Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Grip the bottom right panel and lift to remove it. Grip the bottom right panel and lift to remove it. Grip the bottom right panel and lift to remove it.
    • Grip the bottom right panel and lift to remove it.
  4. Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart. Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
    • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
  5. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  6. Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard. Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard. Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
  7. Unplug the bottom left connector by squeezing it and pulling it away from the board. Unplug the bottom left connector by squeezing it and pulling it away from the board.
    • Unplug the bottom left connector by squeezing it and pulling it away from the board.
  8. Unplug the white wires by squeezing the connector and pulling away from the board. Unplug the white wires by squeezing the connector and pulling away from the board.
    • Unplug the white wires by squeezing the connector and pulling away from the board.
  9. Unplug one set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board. Unplug one set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
    • Unplug one set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  10. Unplug the other set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board. Unplug the other set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
    • Unplug the other set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  11. Cut the cable tie and unplug the remaining wires.
    • Cut the cable tie and unplug the remaining wires.
Conclusión
Una persona más ha completado esta guía.
Jessica Ouyang
Miembro Desde 08/10/18
547 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S15-G4, White Fall 2018 Miembro de Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Miembros
8 Guías creadas
Where can I get the circuit boards for the left and right ?
jfsucher - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 282
